Turbo swap and BatMowheel question. . . - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-16-2013, 05:07 PM Thread Starter
I'm in the midst of pulling the turbos on a '09 F450 WH, replacing them with BD's reman units, figured it would be an opportune time to throw in some Batmowheels. Can't seem to find any threads of anyone installing them in the HP side tho. Didn't know if they were worth it to put in both sides or just the atmo. Also, being these would be newly rebuilt, would I still need to replace any seals or gaskets?
Deviant Diesel is offline
post #2 of 6 Old 09-20-2013, 06:41 AM
BatMoWheels are an absolutle worth upgrade. More horsepower, more torque, lower EGTs, 10% more flow. I plan on getting a pair for my truck and doing some dyno testing. A lot of my friends have them on D-max, cummins and powerstreokes not to mention gas cars too. Well worth it. You will not need any new gaskets or such. Unbolt the compressor housing and undo the nut for the compressor wheel. You will need to hold the turbine wheel so it doesnt spin.
I highly recommend both. 10% more flow on the low pressure and high pressure is great. Faster spooling by a couple hundred rpm
Dr.Lip5hitz is offline
post #3 of 6 Old 09-20-2013, 07:31 AM
cbenn's Avatar
Quoted: 3 Post(s)
Can you do what you want to both turbos without removing the turbo's?
2017 F350 Lariat Dually
Airlift air bags W/ Wireless remote.
2.5 Icon coil springs
PMF adjustable track-bar
PMF dual steering stabilizer
cbenn is offline
post #4 of 6 Old 09-20-2013, 10:23 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yes you can. There is a guy on the army (Jerry) that did a write up of how to install the batmowheel's without removing the turbos. I think his username is 08bigrig.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 6 Old 09-20-2013, 10:35 AM
WoodBoy's Avatar
You are much more money ahead to buy a 71mm from elite or RCD than spending $800 on batmowheels
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #6 of 6 Old 09-20-2013, 10:36 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ I agree completely! As a matter of fact I went with the 71mm
08 F350 cc/sb 4X4
