swapping a lift kit - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-16-2013, 03:25 PM Thread Starter
swapping a lift kit
Hey guys, got a quick question. My brother has a BDS 4" lift kit on his 06 F350 powerstroke and he is getting an 09 F450. I have an 09 F350 that I would like to swap his lift kit onto.
He just got the BDS parts for the front end as he added the extra heavy leaf springs in the rear that raised it 5"(after he broke his main leaves with a salt spreader).
I have air bags on the rear of my truck(we own a landscaping company and haul lots of equipment) so I am ordering a set of PMF rear track bars with a 3" lift block (over stock). So the lift block plus my adjustability of air bags will put me between 4-6" of lift in the rear.
Will the parts from the BDS kit swap over? My main concerns are the track bar relocation bracket and the radius arm drop brackets. I havent been able to cross reference part numbers so thats why I coming here.
Let me know if you guys have any ideas or need more info.
Also, these are both srw 350s, mine is a cc lb, his is a sc lb.
09 F350 SRW- H&S Mini Maxx with KEM 7 tune card, AFE 4" dpf/doc delete, AFE PG7 drop in soon to be S&B CAI, and some other exterior/interior work
06 F350 SRW- IDP Livewire tuned, studded, CAI, 4" DP to empty, Sinister EGR Delete, 6.4 Banjos & Blue spring, New: oem turbo, ficm, oil cooler etc...
02 2500HD- Hypertech programmed, true duals, AEM CAI
066.0 is offline
post #2 of 3 Old 09-16-2013, 09:37 PM
wired1's Avatar
the two parts that dont fit are the track bar drop bracket and sway bay links. everything else fits. I went threw this when I put my 09 lift on my 06.
2013 F150 FX4 EcoBoost fully loaded with the app pkg on Icon 2.5" coilovers
06 F350 Lariat-PMF 8" on 37'sSold
09 F350 ccsb Pmf 7" on 37's Sold
01 F250 ccsb 6" on 35's with to much to list Sold
98 Cobra Vert 583 RWHP Sold
wired1 is offline
post #3 of 3 Old 09-17-2013, 03:06 AM Thread Starter
Thanks for the heads up! I'll order a new relocation bracket then. I was planning to get the PMF sway bar end links anyway b/c I have a boss plow mount that mounts over and replaces the stock sway bar brackets that hold it to the frame rails, so I need a slightly more custom size.
066.0 is offline
