Can the 6.4 Engine be pulled without removing the cab? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-11-2013, 08:08 AM Thread Starter
Quoted: 6 Post(s)
I am unfamiliar with the 6.4L trucks. Can the engine be pulled without removing the cab? I have no way to lift the cab and i need to replace a bad engine. THanks
DENALI is offline
post #2 of 12 Old 09-11-2013, 08:16 AM
No. You can't even change the oil cooler without lifting the cab.
Moto2four is offline
post #3 of 12 Old 09-11-2013, 08:20 AM
Trigger01's Avatar
Nope. If I had done my homework a little better . I wouldn't have bought a 6.4 for that reason. Two days after I bought mine it went in the shop for two weeks and I got a 5k bill(cab had to come off).
2008 F-350 Lariat 4X4 CCSB
Trigger01 is offline
post #4 of 12 Old 09-11-2013, 10:45 AM
DisposableHero is offline
post #5 of 12 Old 09-11-2013, 12:40 PM
The engine can be pulled without removing the cab. I've seen it in videos. It doesn't look easy at all, but yes, it can be done.
B. Adams is offline
post #6 of 12 Old 09-11-2013, 07:48 PM
RHKA's Avatar
CAB ON ENGINE REMOVAL
Hope this helps, courtesy of mts678.
http://www.aev.com/uploads/file/BodyOn64EngineMtnc.pdf
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #7 of 12 Old 09-13-2013, 03:15 AM
Pretty awesome link you have there just curious is that from a T.O.? Format looks right, I might have to look that number up when I go in to work to tonight. And if it is the detail in those pics is amazing the ones we have for the aircraft systems I work on aren't that detailed.
2008 F-350 Lariat TRCCSB Lifted, Tuned, and Deleted
2003 Mach1 Bassani, 4.10s, pro5.0, bama tuned
thnderchcken is offline
post #8 of 12 Old 09-13-2013, 03:28 AM
RHKA's Avatar
I'm not really sure where it's from, but looks like its right out of the service manual. Glad I got my hands on it saved me a lot of time and effort when pulling my 6.4, and if you work on aircrafts this should be a breeze lol just note everything that it says is one time use, don't reuse and take short cuts just replace, because pulling this engine is a pretty lengthy process, take your time do it right THE FIRST TIME.
6" FABTECH LIFT
RHKA is offline
post #9 of 12 Old 09-13-2013, 03:39 AM
Ok well the reason I'm interested is because we do have 6.4 trucks as shop trucks and I figured that vehicle maintenance uses technical orders for there tasks I just didn't know what T.O. It would be under. So if I can find that T.O. then I might have access to a write up on everything from torque specs for lugnuts to troubleshooting engine issues because all that info would be in there or a T.O. in that series. Fingers crossed
post #10 of 12 Old 09-13-2013, 03:44 AM
RHKA's Avatar
Hopefully you get your hands on it. Then you can share it with the rest of us
6" FABTECH LIFT
RHKA is offline
