ECT Help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-10-2013, 11:59 AM Thread Starter
FisherFord's Avatar
ECT Help
Gents,
I have been scouring forums and Google looking for the issue I am having with my truck and I am hoping someone can provide some insight.
Sorry for the long post but I am going to try to answer the question I would ask.
I have maintenance my truck at half intervals of what ford calls for, oil and filter every 5k, and fuel filter every 10k. I did my transmission and coolant the first time at 30k, and replaced the coolant with the gold stuff at them time.
The Truck developed a radiator leak last fall. I believe I caught this early enough as the truck is parked on concrete when I noticed it; I stopped driving it and ordered parts. I replaced the radiator, and while I was at it, did a full erg delete, replaced the coolant with fleet service ELC, new thermostats, upgraded the thermostat hose to the white one and all was well.
This summer I started noticing that my Oil Temp was creeping up a bit, nothing too bad, 203 as a high on the interstate (Yes I am a gauge junky). So I went back to watching my spread, ECT to EOT, and they maintained no more than a 5* spread.
Over the summer this has progressively gotten worse with the same outside temps as before (80ís Ė 90ís). I still see the same spread but the temps kept ticking up, to where now running on level ground at 70mph I frequently see 206 EOT, with an ECT of 200 to 202, not towing. Not bad from what I have read, but what I am noticing is that ECT temps spike and drop with acceleration. I pull a ramp to get on the interstate and I will go from 194* ECT to say 200, and my oil temp will soon follow and climb to the 206 range and maintain. Getting off the interstate for example sitting at light waiting to turn all temps come back in line, 194 ECT and 199 EOT. As soon as I start to move again so do the temps. My concern is how fast the ECT temps are moving, I mean in a couple hundred feet, under normal acceleration it will go from *194 -196* to 200 or over? It shouldnít move this fast. On some cooler nights, my temps donít get as high, but I am still seeing the same ECT movement. So I parked it.
I donít get it? The truck runs great, I donít see evidence of oil in the coolant; I donít see evidence of puking, curious if it maybe a clogged oil cooler, head gaskets, water pump?
I am planning on changing the thermostats this weekend with fingers crossed it fixes this issue, figured itís the cheapest simplest place to start.
Thoughts, advise, punches to the gut (oil cooler)? 
2008 F250 CC FX4,Spartan,FloPro Cat/DPF Delete, Magnaflow Exhaust, S&B Intake,Kenwood DNX8120
FisherFord is offline
post #2 of 7 Old 09-10-2013, 01:23 PM
In my opinion, your numbers aren't out of line. They're well within normal ranges, and the ECT and EOT aren't too far apart. I don't think your oil cooler has any issues.
I think your truck is just fine.
B. Adams is offline
post #3 of 7 Old 09-10-2013, 03:29 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yea it doesn't sound like your numbers are out of line. As long as the EOT is not getting way higher than the ECT your oil cooler is working fine. I also think your truck is just fine
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 7 Old 09-10-2013, 05:09 PM Thread Starter
FisherFord's Avatar
Thanks for the responses! I feel a little better about the oil cooler, although the ECT jumping up so quickly still bothers me, but will see if changing it out this weekend has the desired effect.
post #5 of 7 Old 09-10-2013, 05:47 PM
matted2thefloor's Avatar
I too agree...seems normal. My temps go a tick higher on the interstate too, but remember it's a diesel...the temps will be slightly elevated with steady throttle due to the combustion process and adding in low levels of boost on top of that. In town, mine rides at 192-194 ECT...on the interstate it will hit 198. A small block Chevy usually runs 195-210 for comparison sake...
Don't sweat it...
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #6 of 7 Old 09-10-2013, 06:20 PM
srjd's Avatar
Quoted: 2 Post(s)
Your fine. Since I've switched to h&s my temps run a bit different but on cooler nights at a light 188 ect and on the interstate in the summer 198ect and 201 oil. Usually a 5-6 degree spread. I was paranoid for the longest time but now as long as my spread stays within 6 its all good. Mine cools down fast too if I pull off the interstate
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #7 of 7 Old 09-11-2013, 10:30 PM
Diesels make very little heat at idle so when you get off the interstate and the torque converter unlocks and/or there is no load on the motor the temps will drop because the thermostats cant predict the lower load and keep the temps at a steady level. My temps on the highway are usually 199 ect and 205 eot at 65. I have 4.30 gears and a lift so at 70 the boost,egt's, and temps go up. Once off the highway itll drop a few degrees on each its no big deal
lazlow is offline
