Broke a part while putting my EGR Delete kit on.. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-10-2013, 07:11 AM Thread Starter
buckcgs's Avatar
Hi guys, well it took me three days but finally got my PTP EGR delete kit on. That was a hard task for me. I am not even a fair mechanic or self fixer. When i took the battery box out i broke the nipple at the bottom where the vent tube plugs in. IS this a concern for me to have to buy a new battery box? Also i see on this site that half and half on here says you need a waste gate after a delete. Is that true? thank you guys.
buckcgs is offline
post #2 of 5 Old 09-10-2013, 09:26 AM
You don't need a wastegate.
The part you broke came off of the vacuum reservoir, which is the bottom part of the battery box. I suppose you could try just clamping off the hose, but your vacuum might be slower to respond for things like 4wd and air conditioning.
You could probably fix it with the right parts, but I don't think the whole assembly is terribly expensive. You can probably find something at the hardware store that would work. It's technically drivable in its current condition, but your vacuum pump will run constantly with that hose unattached.
Also, removing the EGR coolers is big job. I bet it feels good to have it done!
B. Adams is offline
post #3 of 5 Old 09-10-2013, 11:20 AM Thread Starter
buckcgs's Avatar
Thanks B. Adams, it does feel good to have that off the truck. Thank you for your response i will see if i can fix it or if so buy another battery box for the truck. Thank you again.
buckcgs is offline
post #4 of 5 Old 09-11-2013, 07:17 AM
CNYWhiteDually's Avatar
look at junk yards!! a couple by me have 08+ f350/250 trucks
alot cheaper than new
CNYWhiteDually is offline
post #5 of 5 Old 09-11-2013, 07:39 PM
Clayton1985's Avatar
I broke my vacuum line under battery box when I did my egr delete 2 years ago. Still havent bothered to fix it.......flimsy POS lines anyways, I just unplugged my vacuum pump and manually lock in my hubs when I need 4x4....
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
