Are all trucks wired for upfitter switches? - Ford Powerstroke Diesel Forum
post #1 of 40 Old 09-09-2013, 01:10 PM Thread Starter
First, the question. Are all 2008 F350's wired for upfitter switches? Wired, as in, they have the 14401 plug that power the switches.
The story;
I have begun installing newly purchased upfitter switches on my '08 KR F350. Everything went smoothly until I tried to find the 14401 harness. I am pretty mechanically inclined, and I know where the thing is supposed to be. I also know that it should be light grey, and have a plug in it that has to be removed. I have literally spent hours looking for this thing. Am I just blind?
Here is where I'm looking.
CobraChris is offline
post #2 of 40 Old 09-09-2013, 01:14 PM
Lilfarmrboy's Avatar
Lilfarmrboy is offline
post #3 of 40 Old 09-09-2013, 02:55 PM
Quoted: 5 Post(s)
I'd like to know as well since I am having the same issue at the moment.
2008 King Ranch CC/LB
DPF Delete, S&B CAI, H&S Mini Max, EGR valve and cooler delete, new downpipe, level Kit, double steering stabilizer, 35's on 18's, Bilstien's, and a Valentine V1
caliboy@heart is offline
post #4 of 40 Old 09-09-2013, 03:01 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
My 2005 Larriot was. It was a plug and play type of thing. Ill bet your's is. I think Ive read they all have the same wiring harness, just not all the goodies that can be plugged into the harness.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 40 Old 09-09-2013, 03:30 PM Thread Starter
Glad I'm not the only one! I've searched and found a couple threads where guys had issues finding the plug, only to find it later, but I've been under this dash for quite a while with no luck. And it's not like I'm not somewhat familiar with it, I've swapped all three blender motors, I've had the dash almost entirely out of the truck, I'm just lost with this.
post #6 of 40 Old 09-09-2013, 03:32 PM Thread Starter
That was my understanding, but I'm starting to doubt it. Unless the guy that built mine was having a bad day, and just hid the thing. It's no where around the place that Ford says it is for sure. You can see from the pic that I know where it should be
post #7 of 40 Old 09-09-2013, 03:35 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im remembering something about the plug being behind the glove box???? Damn bong water on the brain......
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 40 Old 09-09-2013, 03:38 PM Thread Starter
From the pics I've seen, and from the ford directions, it is above the gas pedal, on the brace that runs to the tubular brace. This is on the 2008-2010 trucks.
post #9 of 40 Old 09-09-2013, 03:38 PM Thread Starter
6.4 upfitter switch install - PowerStrokeArmy
post #10 of 40 Old 09-09-2013, 03:58 PM
Quoted: 5 Post(s)
Originally Posted by CobraChris View Post
Damn...not a member so I cant view the PDF.
