08 dyno results - Ford Powerstroke Diesel Forum
post #1 of 12 Old 09-08-2013, 05:20 PM Thread Starter
sicwitted44's Avatar
Send a message via Yahoo to sicwitted44
08 dyno results
Wanted to let you guys know how my truck did on the dyno. First ill let you know about my setup. 08 kr cc sb, h s minimaxx race tuner, sinister egr delete, diamond eye dpf delete, s b intake, sinister coolant filter, 4" lift, 18" race line wheels, Toyo 35 12.50s. I normally just leave the truck on the no power setting because my truck is normally used just for towing the boys dirt bike trailer or the family boat but I wanted to see what she could do on the dyno on the hot damn setting. So I drove it about 300 miles on the hot setting to let the tranny learn the power setting. Then dyno days arrived and she put down 472 rwhp and 871 ft lbs torque. Amazing numbers for tuner only power. People are dumping pretty serious dollars on there dura max and cummins to see those numbers. The 6.4 is a beast.
sicwitted44 is offline
post #2 of 12 Old 09-08-2013, 07:26 PM
So you dont even have a full exhaust system? Wow! My truck has a dpf and cat delete, stock exhaust otherwise, spartan tuner, and an S and B intake (not installed yet), I sure wish I was near a dyno to see how it would do, I think your numbers are sweet!
preppypyro is offline
post #3 of 12 Old 09-08-2013, 08:10 PM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Numbers seem pretty low... IMO. You should be close to the 600's. My 6.4L with similar mods dyno'd 578 RWHP. Same tunes, same size tires.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #4 of 12 Old 09-08-2013, 09:22 PM
srjd's Avatar
Quoted: 2 Post(s)
Wonder why his was about 100hp lower. Most are in the 575 range on that tune
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 12 Old 09-09-2013, 03:51 AM Thread Starter
seems about right to me, hot damn tune puts hp at engine about 650. couple that with the25 to 30 percent loss to rear wheels due to drivetrain. Those numbers are exactly what I expected to get out of her. How could you you expect to get 550 or 570 at rear wheels. that's only a loss of 80 to a hundred horse to the drivetrain. Not saying you guys are wrong but 550 seems like a pretty high number to expect from my setup
post #6 of 12 Old 09-09-2013, 05:11 AM
Seems low to me. Depending on Exhaust set up and intake that along should add another 75hp or so. The stock exhaust is very restricting. I know by adding an intake you can see 20rwhp
Tjmaxx is offline
post #7 of 12 Old 09-09-2013, 05:13 AM
superduty6.4's Avatar
Did you have it on the highest setting? They are just saying it seems low because everyone else that has dynoed that setting with similar mods have been at the 570 hp range. Maybe you were just dialed down a couple settings
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #8 of 12 Old 09-09-2013, 06:03 AM Thread Starter
Maybe something is up with my truck, don't really know where to start looking. If you guys are all seeing those numbers that must be about right. It was definitely on the hot damn setting. Before dyno I changed all my fluids and filters and it seemed like my tranny was hitting really hard and healthy. Not sure where I could be losing a hundred horse
post #9 of 12 Old 09-09-2013, 06:51 AM
Maybe the defuel settings are low
g4dadon is offline
post #10 of 12 Old 09-09-2013, 08:15 AM
Like posted above, maybe the defuels were on and it was in the process of defueling or you may have even been 1 setting beloew the performance setting which is the 225hp setting. Who knows. Either way as long as you are happy with the truck that's all that really matters.
08 F350 JOB 1
2.5" LEVELING KIT
CCV MOD
AFE CAI
PMF TRACTION BARS
