6.4L Injection Pump - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-08-2013, 07:32 AM Thread Starter
6.4L Injection Pump
Hey all!
I have a 2008 F550 with a 6.4L Powerstroke, and the Ford dealer tells me my high pressure pump (injection pump) is faulty. Of course they want to charge me to remove the cab and replace it for a ridiculous amount of $$$...
I was wondering, is it even possible to replace the injection pump without removing the cab? I know it would be much easier to remove the cab but I don't have a hoist and if it is possible i'd like to do it myself. I would also like to know some components to remove first to make it easier access.
Thanks!
DMC_DIESEL is offline
post #2 of 3 Old 09-15-2013, 08:21 PM
CFoster's Avatar
Just did mine and yes the cab has to come off...after that it is pretty simple
F250 CCSB FX4
Spartan dashdaq
,deleted,RCX 4-link 6" Lift, 325/60R20 Goodyear Duratracs, 20x10 Gear wheels, 15% tint,RBP step bars.
CFoster is offline
post #3 of 3 Old 09-18-2013, 09:03 AM
Yes, search for "HPFP cab on" and you should see some good info. I had the P0088 code on my '10 and ended up fixing it by the dealer doing a $250 reflash of the computer. Havent had an issue since.
Here is a link to a cab on HPFP replacement: First timer 6.4 cab lift to replace HPFP
Hope this helps.
2010 F-250 ECLB 4x4 6.4l Powerstroke, 155,xxx miles, H&S Mini Maxx, 5" Flo-Pro Straight Pipe
Previous Trucks:
2005 Dodge Ram 2500 cummins diesel, QCLB manual, 270,xxx miles, stock
1999 ford F-250 RCLB 4x4 7.3l Powerstroke, stock
Blacksoot05 is offline
