a/c question - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-06-2013, 07:17 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
a/c question
Ok guys so on Monday I used my truck and the a/c was working fine. On Tuesday and Wednesday I used my bike. Yesterday I went in the truck and the a/c wasn't working. It didn't seem like the clutch was engaging. Do you guys think that maybe its something simple like a fuse? Any ideas are appreciated. Thanks.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #2 of 16 Old 09-06-2013, 07:30 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
I lost the ac in my '05 an '12. And both times it was due to low pressure in the system. Both times, topped off the system and the ac's are back to doin what the y do best. With low pressure the compressor on the 05 would cycle on and off. On the 12 it wouldn't try at all.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 16 Old 09-06-2013, 07:39 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yesterday it wouldn't blow out cold at all. So you think its low on Freon?
08 F350 cc/sb 4X4
post #4 of 16 Old 09-06-2013, 07:45 AM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 274 Post(s)
Most likely.. And the low pressure switch isn't allowing it to run because of the low charge. Easiest way to test this with out buying a gauge is jumping out the low pressure switch
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #5 of 16 Old 09-06-2013, 07:46 AM
Quoted: 274 Post(s)
Guess I should explain how. Unplug the harness from the low pressure switch and jump it with a paperclip
post #6 of 16 Old 09-06-2013, 07:47 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
I guess I will have to take it to get charged. How would I go about jumping the low pressure switch?
08 F350 cc/sb 4X4
post #7 of 16 Old 09-06-2013, 07:47 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
Haha I just asked you how. Thanks!
08 F350 cc/sb 4X4
post #8 of 16 Old 09-06-2013, 07:52 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
One more thing. Where is the low pressure switch?
08 F350 cc/sb 4X4
post #9 of 16 Old 09-06-2013, 08:12 AM
Quoted: 274 Post(s)
Without actually seeing an 08, it is usually found on the suction accumulator ( big aluminum cylinder found on the passenger side of the engine bay)
post #10 of 16 Old 09-06-2013, 08:15 AM Thread Starter
04hdfatboy's Avatar
Quoted: 4 Post(s)
If it is low I must have a leak because I just had it charged at the beginning of the summer.
08 F350 cc/sb 4X4
