Is this fuel filter normal? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-04-2013, 06:14 PM Thread Starter
CajunMan's Avatar
I have never changed the lower fuel filter myself. First thing I notice is the drain lever is broken, then I notice the assembly is saturated with diesel. So I'm guessing whoever has been changing the fuel filter must just drain it from the cap, or do I have something wrong. Have any of you seen this before?
3" Rough Country, 18" Ballistic Jester, 35" Dunlop Fierce Attitude, S&B CAI, H&S Black Maxx, Gearhead Race Tuned, 4" FloPro Exhaust, Sinister EGR Delete with Intake Elbow, MBRP CAC Pipe, Sinister Coolant Filter
CajunMan is offline
post #2 of 7 Old 09-04-2013, 06:15 PM Thread Starter
CajunMan's Avatar
Forgot about the picture
CajunMan is offline
post #3 of 7 Old 09-06-2013, 05:27 AM
dbllung's Avatar
Its either seeping a bit from the broken off drain valve or without the drain valve, diesel is going to make a hell of a mess when you try to change filter.
I would imagine that without releasing the pressure with the drain valve that diesel would spray everywhere (which is what it looks like in the photo) if you just unscrewed the filter.
If it were me, I'd replace the drain valve.
dbllung is offline
post #4 of 7 Old 09-06-2013, 09:09 PM Thread Starter
CajunMan's Avatar
Thanks. I made it a point to pick one up today
CajunMan is offline
post #5 of 7 Old 09-12-2013, 01:08 PM
How was the replacement? I plan to order the rebuild kit online for 35 or whatever it was, and do that next time, but I actually didn't lose that much fuel when I did mine with it already broke off.
Like to hear how the replacement goes.
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #6 of 7 Old 09-12-2013, 01:58 PM
RHKA's Avatar
Real simple, three 1/4" torque head bolts, and the valve/cover comes out. I think the torque size is t25 but don't quote me.
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #7 of 7 Old 09-12-2013, 07:43 PM Thread Starter
CajunMan's Avatar
It was very easy to install. It has two green o rings that were bad. I replaced those also, which comes with the kit. The drain valve is all one piece, so I turned the drain with a needle nose. There was a lot of crud where the o rings were sitting, so I cleaned it a best I can. You should be able to do this no problem.
CajunMan is offline
