Violent Front Wheel Hop - Ford Powerstroke Diesel Forum
post #1 of 21 Old 09-04-2013, 03:09 PM Thread Starter
Quoted: 5 Post(s)
Well, I haven't been on here a long time now, but I have an issue I hope you all can help me out with. This happened back in July and it just happened again this weekend. When I have a load in the bed (small or large) and I hit a bump in the road, a seam in the concrete/asphalt or even an pot hole at highway speeds (above 50 mph) the front driver side wheel violently shakes up and down and vibrates the whole truck. It's enough to scare the you know what out of me and it only stops if I brake down to around 35-40 mph. This last weekend, it almost caused a wreck! I know it's not a balance problem because I just had that done. I searched Google and got all kinds of crazy culprits. I also searched here but only found threads about the rear end shaking and folks adding traction bars. Since it's my front end, this doesn't help.
2008 King Ranch CC/LB
DPF Delete, S&B CAI, H&S Mini Max, EGR valve and cooler delete, new downpipe, level Kit, double steering stabilizer, 35's on 18's, Bilstien's, and a Valentine V1
caliboy@heart is offline
post #2 of 21 Old 09-04-2013, 03:28 PM
Wyofordpower's Avatar
Quoted: 2 Post(s)
Have you ever put slime, or any other tire repair goo in the current tires?
We had an 08 work truck that someone put slime in the tires and now if you take a corner too fast or hit a large bump n the road the whole truck shakes from the front tires vibrating.
Wyofordpower is offline
post #3 of 21 Old 09-04-2013, 03:41 PM Thread Starter
Quoted: 5 Post(s)
No sir, no slime or any tire repair. It only does it when there is a stuff in the bed and I hit a bump going straight.
post #4 of 21 Old 09-04-2013, 03:44 PM
Raul@Stealth Automotive's Avatar
what type of leveling kit are you running?
Raul@Stealth Automotive is offline
post #5 of 21 Old 09-04-2013, 03:54 PM Thread Starter
Quoted: 5 Post(s)
Just 2.5 inch spacers between the buckets and the coils.
post #6 of 21 Old 09-04-2013, 03:55 PM
and your shocks are fairly new? are they the correct size for the leveling kit?
post #7 of 21 Old 09-04-2013, 03:59 PM
Quoted: 28 Post(s)
Ball joints or the joints on the long bar joining the frame to th axle, I forgot its name
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #8 of 21 Old 09-04-2013, 04:08 PM Thread Starter
Quoted: 5 Post(s)
Shocks are new bilstiens put on about a year ago and they are the correct size.
post #9 of 21 Old 09-04-2013, 04:08 PM
977300's Avatar
Are you sure it is a hop and not "death wobble"?
97 F-Super Duty 5 speed...T&S Performance Chip. More upgrades to come.
95 F-Super Duty 5 speed. The current project.
94 Dodge 2500 SOLD!
94 Dodge 3500 Sold to buy Superduty parts
95 Dodge 3500 Sold to buy more Superduty parts.
03 Dodge 3500 SRW, 4 door, 4X4, Cummins
Banks exhaust. Transmission upgraded.
977300 is offline
post #10 of 21 Old 09-04-2013, 04:09 PM Thread Starter
Quoted: 5 Post(s)
Really? Is this something that has a TSB?
