Filters??? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-04-2013, 05:45 AM Thread Starter
Filters???
Just out of curiosity, which filters are the best? I understand a lot of you run Motorcraft filters, which if its good enough from the factory, its good enough forever. But i was wondering if anybody else may be running different filters, say Wix for example? what are the pros and cons? any input would be appreciated!
MovinOnUp is offline
post #2 of 14 Old 09-04-2013, 06:03 AM
Definitely do a search on this, been covered multiple times. With that said, Motocraft and Racor(Motocraft just not a pretty box and packing) are the only 2 filters you should be running.
dieselfiltersonline.com , thank me later.
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #3 of 14 Old 09-04-2013, 06:12 AM
ngaraiderman's Avatar
Also performance truck products.com offers free shipping on orders over $50.
Only use racor/motorcraft filter
ngaraiderman is offline
post #4 of 14 Old 09-04-2013, 07:44 AM
OEM only on this thing! The reason is that Ford will void your warranty if you use the wrong filter and have a fuel system issue. Secondly, they are really the only filters that can meet the needs of the engine.
Expirobo is offline
post #5 of 14 Old 09-04-2013, 10:29 AM
If you want to make your life easy just go to dieselfiltersonline.com click on 6.4, click on oil fiters, click on Motorcraft. Then as your checking out it will automatically ask if you want to add Fuel Filters and you just click yes. Delivered to your door in a day or two.
Then go to Walmart and buy 4 gallons of Rotella T-6.
(P.S. - there is a video on the dieselfiltersonline website that shows why you want to use Motorcraft.
seafordguy is offline
post #6 of 14 Old 09-04-2013, 10:56 AM Thread Starter
Thanks for all the input fellas! Much appreciated!
post #7 of 14 Old 09-04-2013, 07:52 PM
Nothing wrong with using oem filters. My only issue is the videos on the diesel filter site don't pertain to the 6.4L. The second video try's to use the 6.4 when comparing oil filters but only shows ones that come with caps. I've never seen a place that sells an oil filter with an aftermarket cap for he 6.4. I know te 7.3s come with caps. Then they show a bulletin from ford about using aftermarket filters but again it only pertains to the 6.0. Is there a bulletin for the 6.4? If so why not post that in the video?
I got stuck using a fram tough guard oil filter and az fuel filters from autozone. After comparing them to the oem filters I took out they were identical. They shared the same measurements and looked exactly a like, the fuel filter even has the tiny air bleed hole in it that's found on the oem filter.
And they can't void your warranty for using aftermarket parts, it goes against the Magnuson-Moss Warranty act
"Warrantors cannot require that only branded parts be used with the product in order to retain the warranty."
jgos929 is offline
post #8 of 14 Old 09-04-2013, 08:09 PM
ZMANN's Avatar
Quoted: 1464 Post(s)
they can void your warranty for using aftermarket parts that don't meet their specifications or that they can prove lead to a failure
it's just silly to save a buck
actually they can
We Miss you Ronnie
ZMANN is offline
post #9 of 14 Old 09-04-2013, 08:13 PM
ZMANN's Avatar
but then they would have to provide those parts free of charge LOL
We Miss you Ronnie
ZMANN is offline
post #10 of 14 Old 09-04-2013, 08:37 PM
actually they can
Now I'm only talking about filters here, not tuners or dpf deletes etc.
Just about every after market filter on the market "meets or exceeds oem specifications". If that wasn't the case they wouldn't be allowed to advertise it and it wouldn't be a part of the Magnuson moss act. The point is warranty providers in the past used to say your not using oem then we ain't fixing it. Then congress came along and said wait a minute there are people out there producing products equal to or better quality than yours and parts are still failing so no more using that excuse.
If you don't believe big companies with multi billion dollar r&d departments can produce a filter that's as good if not better than oem well then I don't know what to tell you. Plenty of folks denied HPFP replacements under warranty while using oem filters because they found rust in the bowl. Explain that?
Saving a buck??? Shoot I actually paid $10 bucks more from autozone than I could have buying from diesel filters
OEM here on out for me
jgos929 is offline
