Pouring water when A/C is on...pouring! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-02-2013, 07:22 PM Thread Starter
Down2Ride's Avatar
Truck has been sitting for a few months due to some trouble with the law. Been cranked every few days just to keep it in check. Cleaned it up to get back on the road and noticed water pouring on the ground when the A/C is on. I know there should be a drip, but there is a river flowing down my driveway. What could be the problem? Air blows cold, but worried about the amount of water going to the ground.
'08 F250 Crew Cab King Ranch 6.4L (White)
4" Zone Offroad Lift
Spartan Tuned
Spartan TCM
DPF/CAT Delete
EGR Delete
ARP Head Studs
S&B
MBRP
35x12.50x22 TOYO M/T
Down2Ride is offline
post #2 of 5 Old 09-02-2013, 07:23 PM Thread Starter
Down2Ride's Avatar
Water coming from drain in firewall on passenger side. It's a hole, I'm guessing its a drain.
Spartan Tuned
Spartan TCM
DPF/CAT Delete
EGR Delete
ARP Head Studs
S&B
MBRP
post #3 of 5 Old 09-02-2013, 07:29 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
The higher the humidity, the more water you will see. I doubt you have an issue.
dhanna6powerstroke is offline
post #4 of 5 Old 09-02-2013, 07:35 PM Thread Starter
Down2Ride's Avatar
Ok. Thanks. I'll keep an eye on it.
Spartan Tuned
Spartan TCM
DPF/CAT Delete
EGR Delete
ARP Head Studs
S&B
MBRP
post #5 of 5 Old 09-25-2013, 11:27 AM
mthompson's Avatar
Being that you are in MS, I'd say it is just a lot more condensation than usual because of the high humidity.
Mine was dumping lots of water last week with dew points in the 70's here.
MT
mthompson is offline
