Lower fuel filter only half used? - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By CrazyS0b
post #1 of 8 Old 09-02-2013, 06:17 PM Thread Starter
44magnum's Avatar
Ok, here's a new one.
I was changing my fuel filters today as they were overdue, did the top filter and while dirty it looked normal, then I changed my lower fuel filter and when I pulled it out, it only looked half used. Half of it was almost as clean as the new one, while the other half was very dirty. IIRC they are factory ford filters. I always do the purge procedure after a filter change, I empty the water separator often. Any Ideas?
Half and half.....
The dirty half......
The clean half......
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #2 of 8 Old 09-02-2013, 08:33 PM Thread Starter
44magnum's Avatar
I have been informed that is not an OEM filter, and it seems to be missing a weep hole.
44magnum is offline
post #3 of 8 Old 09-03-2013, 09:14 AM
That's weird.
I don't use oem filters and haven't ever had that happen.
jgos929 is offline
post #4 of 8 Old 09-03-2013, 05:39 PM
ATVJOE's Avatar
Never seen anything like that before, but then I only use the Motorcraft
2008 F250 SD King Ranch 4X4, H&S Mini DPF delete
Job 2 LB SRW Crew Cab AMP Power Running Boards
ATVJOE is offline
post #5 of 8 Old 09-03-2013, 05:56 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Either you have terrible flow, or . . . idk.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #6 of 8 Old 02-18-2016, 06:32 PM
rol
Did anyone come up with a reasoning? My last filter was half black and half clean... Have been having some weird issues with my truck and wonder if this is tied together somehow
rol is offline
post #7 of 8 Old 02-18-2016, 06:35 PM
Your Local Windex Brewer
CrazyS0b's Avatar
Quoted: 371 Post(s)
If you aren't using Ford filters then that's why. They have an air bleed hole that the wix (and most others) do not have. The air bubble on the top of the filter will keep it from filtering properly.
This is exactly why we have always said use Motorcraft filters at all cost...
ZMANN likes this.
2008 F350 SRW CCSB FX4 - Airaid CAI, FloPro 5" straight pipe, SCT X4 Tuned by Gearhead and RCD, Monitored by CTS
-Matthew
CrazyS0b is offline
post #8 of 8 Old 02-19-2016, 01:41 PM
rol
That's what I figured...don't know what kind it was when I bought the truck but all are motorcraft now
rol is offline
