just bought 08 f250 6.4 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-02-2013, 07:54 AM Thread Starter
Hey yall, I just bought a 2008 f250 4x4 lariat. the truck has a 6.4l obviously, and has 180,000 on it. I know the milage seems high but I got a good deal and from what I can tell the truck has been really well maintained. I have a couple of questions though. first off it has a programmer on it. what kind I don't know because I do not have the actuall programmer. what I do know is that it makes a ton of power and seems to be happy with exception to 2 things. first it says check air filter when I start it up. not sure if its not getting enough airflow or not. it is a stock filter. secondly and this just started, my truck keeps killing the batteries. in the morning they are almost completely dead. or anytime after I shut it off. if I jump it the truck runs great, so I don't think its the alternator. bad cell in the battery maybe? and funally how can I tell whats been done to this truck as far as "bulletproofing" goes? i.e. egr delete etc. my first thought is if the truck has 180000 if it had a ton of issues they would have shown up by now right? thank you for your advice input and time
THE BIG FISH is offline
post #2 of 9 Old 09-02-2013, 08:47 AM
Big_Smokey's Avatar
Quoted: 9 Post(s)
if it has the stock air filter it may have an issue with the extra power. sometimes it will screw up....also there is a reset button thingy on your air filter also. may check that does it have exhaust by chance..straight pipe from the front to the back?
Big_Smokey is offline
post #3 of 9 Old 09-02-2013, 09:00 AM Thread Starter
I'm not real sure on what exhaust it has. The tips are stock but it definitely doesnot have stock exhaust. Where is the reset button for the air filter?
post #4 of 9 Old 09-02-2013, 09:42 AM
Big_Smokey's Avatar
Quoted: 9 Post(s)
find the air filter box and you should see it in that area. theres a piece that has red and yellow or something like that....it may not be a reset button, but its an indicator of your filter
post #5 of 9 Old 09-02-2013, 11:24 AM
RHKA's Avatar
It's a filter minder on your intake tube, people running 250+ tunes have problems with it sucking in the filter minder.
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #6 of 9 Old 09-02-2013, 11:31 AM
Mine does this. It's a blue reset button
Tjmaxx is offline
post #7 of 9 Old 09-02-2013, 04:25 PM Thread Starter
Thanks for the info, any ideas on the battery problem. It was fine for like the first 2 weeks, now every time I shut it off the batteries are dea
d.
post #8 of 9 Old 09-02-2013, 06:46 PM
Have you had the batteries checked?
Tjmaxx is offline
post #9 of 9 Old 09-02-2013, 11:35 PM
RHKA's Avatar
d.
Load test the batteries.
6" FABTECH LIFT
RHKA is offline
