Questions on converting to a dually - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-27-2013, 05:43 AM Thread Starter
I have a 2008 Super cab short box and am thinking about converting it to a dually. It is my understanding that Ford actually made a sb dually in that year, but it may have been only in a crew cab. I need more tow capacity, I have a 16,500 lb Toy Hauler with about 3,100 to 3,200 lb pin weight. Can I just add fenders to my current box, change the rear end and wheels? Do I need to change anything on the front so all six wheels match. Does this conversion even make any sense? I know there will be those that say a long bed would be better, and I get that, but I like my short bed since it fits in the garage. I really like my current truck since it only has 42,000 miles and has been deleted with Mini Max, 4" exhaust and S&B intake. Any guestimates on cost assuming I do the work myself?
RDUB is offline
post #2 of 5 Old 08-27-2013, 06:48 AM
andyroof's Avatar
It was my understanding that a dually did more for payload and hardly anything for tow rating...could be wrong though I'm new to this.
L99 F350 eclb 4x4 single axle rear end....stock........for now
andyroof is offline
post #3 of 5 Old 08-27-2013, 07:53 AM Thread Starter
Payload is what I really need more of. When I weighed my rig partially loaded I was 140 lbs over the rear axle weight rating, and a little over 1300 lbs over on the Gross vehicle weight rating of the truck. I did put air bags on and it cured the squat. It actually tows it pretty well, but the amount I am exceeding some of the weight ratings has me somewhat concerned. I am about 150 lbs under the weight rating of the rear tires.
RDUB is offline
post #4 of 5 Old 08-27-2013, 09:54 AM
c69ss396's Avatar
just remember yes you can swap out the rear axle and springs, find a shortbed dually bed and have what your wanting. It will be more stable but it will not change your legal gvw thats on the door sticker.
Dieselsite/Strictlydiesel Efuel, Baby Swamps, Adrenaline HPOP, D66 w/1.0 Housing, ww2, International Uppipes, Swamps tunes, Swamps IDM, Tymar Intake, 5in Exhaust, 203* T-Stat, Aluminum Radiator, 6.0 Fan, Dieselsite Coolant filter, Luk Clutch
c69ss396 is offline
post #5 of 5 Old 08-27-2013, 11:32 AM Thread Starter
Do you really need the dually bed, or can you just add the fenders to the current bed? I am not thinking finding a short box dually bed would be easy to do.
RDUB is offline
