Annoying squeaky noise... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-25-2013, 05:24 PM Thread Starter
Y&R0864's Avatar
I have an annoying squeaky noise coming from the rear end. Can't tell where it's coming from. Only does it when moving forward really slow. Once the speed gets up above 10 mph it just kind of goes away. I've mad a few drives and it doesn't seem that it's lightening up.
Is there any kind of great able bearings or could it be something with the driveshaft?
2008 F250 6.4 crew cab lariat w/s&b intake, flo pro egr delete, diamond eye 4" turbo back, and mini max
Y&R0864 is offline
post #2 of 9 Old 08-25-2013, 05:40 PM
Chorgey's Avatar
I have a similar issue that seems to be from an exhaust hanger. Its a constant noise though. Any little bump at any speed. Horrible when the back window is open. I've used some WD40 on the hangers but that didn't help. Next is using some grease.
May not be your problem, but maybe something to consider with aftermarket exhaust.
Chorgey is offline
post #3 of 9 Old 08-25-2013, 06:03 PM
dieselburner21's Avatar
Quoted: 8 Post(s)
This might be really stupid but mine was doing something similar, the rubber on the inside latches for the tailgate had worn through. Some wd40 fixed that. Worth trying out though, driving around with the tailgate down, to narrow it down
Will
2010 FORD F250 LARIAT CCSB 6.4
-H&S Mini Maxx / Edge Insight CTS / 4" Flo Pro Dump / 20" Fuel Hostages / 33" Toyo AT's / Airdog II 4G
2006 FORD F250 LARIAT CCSB 6.0 - TRADED
2000 FORD F250 LARIAT CCSB 7.3 - SOLD
dieselburner21 is offline
post #4 of 9 Old 08-25-2013, 06:12 PM Thread Starter
Y&R0864's Avatar
Thanks but mine only does it on acceleration forward... In reverse is no problem and no noise. And If I accelerate a bit and let off it will quit regardless of bumps.
Y&R0864 is offline
post #5 of 9 Old 08-25-2013, 06:55 PM
tony97gt's Avatar
I also had the squeaky issue and it was the tail gate latches. Grease fixed it.
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #6 of 9 Old 08-25-2013, 07:03 PM
Check your tailgate latches, exhaust hangers, exhaust clamp connections, bed to frame bolt torque, spare tire tensioner, etc..
Don't be afraid to grab something and shake it, jiggle it, or wiggle it!
Expirobo is offline
post #7 of 9 Old 08-26-2013, 02:16 PM Thread Starter
Y&R0864's Avatar
Well it definitely isn't the tailgate and it's definitely coming from under the truck. I would roll underneath and check it out some more but I'm gonna have to wait till it dries up some.
Y&R0864 is offline
post #8 of 9 Old 08-28-2013, 12:35 PM
kevinah's Avatar
Maybe the spare tire isn't firmed all the way into a right position.
kevinah is offline
post #9 of 9 Old 08-28-2013, 02:34 PM
CajunMan's Avatar
Ujoint. They can be weird like that
3" Rough Country, 18" Ballistic Jester, 35" Dunlop Fierce Attitude, S&B CAI, H&S Black Maxx, Gearhead Race Tuned, 4" FloPro Exhaust, Sinister EGR Delete with Intake Elbow, MBRP CAC Pipe, Sinister Coolant Filter
CajunMan is offline
