Tough Decision 08-10 F450 or 11 F350 DRW - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-24-2013, 07:31 AM Thread Starter
I currently have a 2011 F250 Lariat CC SB I tow my 25' toy hauler with but I am planning on upgrading to a much larger trailer.
The fifth wheels I am looking at have 18k-21k GVWR's thus the need for a bigger truck.
My wife and I love the '11 and we only tow with it so it will never be a daily driver. We are trying to stay in the low $30's so my options are a '08-'10 F450 or an '11 F350 DRW. The '08-'10 trucks have 40-80k miles in that price range but the '11's have 120-140k. Is the Scorpion worth going with a higher mileage truck.
I have read about the 6.4 issues as well as some 6.7 issues. I have also heard that most of the issues could be caused by not having the truck under load most of the time. This is not a commuter. 90% of the time it will have the trailer attached to it.
What do you guys think?? Need some good advice. Thanks.
m32go is offline
post #2 of 9 Old 08-25-2013, 07:09 PM Thread Starter
Nobody?? The '11 F250 is for sale as of today and I'm lookin.
No advice for me. I've gone from 08 f450 to Dodge, to Chevy, but my wife really likes the Ford as do I. I'm just scared of possible repair costs.
Should I be looking for one that towed in the past (fifth wheel or gooseneck) or not. I've heard the ones that towed didn't have as many DPF issues due to the truck being under load.
Give me something to work with......
m32go is offline
post #3 of 9 Old 08-25-2013, 08:33 PM
44magnum's Avatar
Quoted: 2 Post(s)
Well if you plan on running it stock I would say go with the 6.7, if your going to remove the DPF and tune it then go with the 6.4.
That being said I know the 08-10 F450's seem very sturdy, heck the rear axle is a dana 110, which is a square tube heavy heavy duty axle. But the gearing is 4:30 or 4:88 and when mated to the 6.4 equals really really really ****ting mileage. And they have 19.5" wheels which use commercial tires which last longer but ride stiff. I hear the 6.7's get substantially better mileage.
I think the 08-10 F450's are a heavier duty than the 11+ F350's, the question is do you really need the F450?
You say the GVWR of your next tow hauler will be 18-21K, but what do you expect it to weigh?
Also, depending on the states you will be traveling through, you may need a CDL. I know RV's are supposed to be exempt from 26K combined GVWR rules but some states dont seem to think a toy hauler is an RV. Just something to look into, talk to the DMV/DOT of the states you'll be going through.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #4 of 9 Old 08-25-2013, 11:15 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'm jealous, I want to be able to purchase a newer truck just to pull the camp trailer around! IMO I'd get the 2010 6.4 f450 and delete the exhaust junk and get a good tow tune... Possibly one that only tunes the trans but deletes the dpf and egr. Good luck man and make sure to post some pics of your new toys once you purchase.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 9 Old 08-26-2013, 05:28 AM
Def. the F450
2008 F450 KING RANCH
DELETED
H&S MINI
ARP HEAD STUDS
RUDY'S HD UP PIPES
S&B CAI
ALRADCO RADIATOR
OEM PISTON W/HOLE FOR PAPER WEIGHT
5R110W WITH BILLET GOODIES AND AERMET SHAFT
4 CAR WEDGE TRAILER
ALL WORK DONE BY RUDY'S
87K599 is offline
post #6 of 9 Old 08-26-2013, 08:01 AM
F450Harley's Avatar
For that kinda load you have, a 450 is a better match........and also you will get alot more life of a truck with your budget if you go with a 6.4. I would say deleting is a MUST. Good luck to you.
Title on hand like always
F450Harley is offline
post #7 of 9 Old 08-26-2013, 11:44 AM
CNYWhiteDually's Avatar
f450 with a delete and tune, you will be glad you did, alot more life in the truck also
CNYWhiteDually is offline
post #8 of 9 Old 08-26-2013, 11:59 AM
6.4 if you are going to delete. If not go 6.7 and plan on a turbo soon.
2008 Silver F-250 6.4
griz700rocket is offline
post #9 of 9 Old 09-03-2013, 08:46 AM
jac97psd's Avatar
6.4 f450 with dpf delete and tune. Good luck to whatever you get.
2010 F-350 CC SRW LongBed 4X4
Spartan tunes, 5 inch Flo-Pro w/ DPF Delete, AFE stage 2 CAI, Cold side piping, 4 inch down pipe, Rudy's EGR delete, Air Dog II
jac97psd is offline
