Freeway "whoom whoom whoom" soft vibration at 55-60mph - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-22-2013, 01:15 PM Thread Starter
Hey all, pretty much for as long as I've owned this truck, it has had a "whoom whoom whoom whoom" sensation that is audible and I can feel it through the floor slightly. I wouldn't even call it a vibration, more like a harmonic pulse of some sort that drives me nuts.
I just got back from the tire shop and had the tires balanced. They said a wheel weight had fallen off. Result: the truck feels maybe a tiny bit smoother, but the whoom whoom whoom whoom sound is still there.
Wheel bearing? Driveshaft? Rearend bearing? I'm at a loss...
'08 F250 Regular Cab 4x4 (sold)
MBRP dpf delete
MBRP intercooler pipe
S&B intake
IDP/ SCT tuned
Suncoast Trans (built by Quin Trans in Lompoc, CA)
Cal-Tracs
Eaton Tru-Trac
12.76 @ 105.50, 1.80 60ft (before trans or intercooler pipe)
lxcoupe is offline
post #2 of 3 Old 08-22-2013, 03:30 PM
Echo's Avatar
Have you had a front end alignment done? If the alignment is off your tires could be worn in a way that they make that noise at highway speed whether they are balanced or not.
Echo is offline
post #3 of 3 Old 10-13-2015, 06:26 PM
I know this is old, but did you ever sort it out?
Lightbulb is offline
