HELP PLEASE!!! 6.4 shut down n stranded - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-17-2013, 12:33 PM Thread Starter
cbarm's Avatar
I have a 2010 F450 KR pickup n my check engine light came on today. I drove about 50 miles n came to a stop light. When I went to take off it seemed very sluggish and then the screen said "Stop safely now". I drove about 1/4 mile to where I was going n as soon as I put it in park it died. I tried to restart it but absolutely nothing when turning the key. Now the battery and check engine light are on and it makes a beeping sound from the dash...still no click or start or anything. Is my alternator toast??
2010 F450 King Ranch 6.4L 4x4 4.30 ratio 130K miles bone stock
1994.5 F350 XLT 7.3 PSD ZF5 CC DRW 220K miles
cbarm is offline
post #2 of 7 Old 08-17-2013, 01:49 PM
Big_Smokey's Avatar
Quoted: 9 Post(s)
A guy at work and something similar to this happen to him also on his 2010 Fx4. he was towing a 5th wheel camper and had to limp it to a dealership. Seems like it was an electrical issue with his as well, but i cant remember now.
Big_Smokey is offline
post #3 of 7 Old 08-17-2013, 08:04 PM
Clayton1985's Avatar
Sounds like a charging problem. Can you check codes?
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #4 of 7 Old 08-18-2013, 06:52 PM
ATVJOE's Avatar
Mine did this after I bought mine. It happened right after I had the HPFP replaced. They towed it and it was some electrical pump that went bad as well. If you leave the truck sit for about an hour, she will reset and will start, but gets you only another mile or two before going in to shut down. I read something about this before on this forum, just don't remember where. Good Luck
2008 F250 SD King Ranch 4X4, H&S Mini DPF delete
Job 2 LB SRW Crew Cab AMP Power Running Boards
ATVJOE is offline
post #5 of 7 Old 08-19-2013, 03:02 AM
Quoted: 48 Post(s)
most common is the temp sensor after the dpf. I keep spares on hand. I've gotten somebody off the side of the road before
drunk on diesel is offline
post #6 of 7 Old 08-27-2013, 05:27 AM
get it scanned for codes that will help out a lot, if i were to guess i would agree with drunk on diesel, and i would say, exhaust temp sensor or egr temp sensor,
goldgoose is offline
post #7 of 7 Old 08-31-2013, 04:54 AM
ajordan6337's Avatar
could be anything
These trucks will do this for anything wrong at all and they wont let you start it until the problem is fixed. You can unplug a sensor and it do the exact same thing.
Sadly if you cant diagnose the problem yourself then you gotta take it to ford most likely.
Your engine could have been in reduced power mode when it was sluggish.
Wont go to 2000 rpm? then its probably in reduced power mode.
08 F-250, 6.4, King Ranch, captains, ccsb, 8 inch rough country, 37's on 22' monsters, volant intake, sct livewire innovative tunes, 5 inch turbo back flo pro, top gunz customs control arms, Iron bull
07 Mustang, GT/CS, LT's, Custom 3inch Straight Pipes, 20 inch Razors, Spector
11 F-450, 6.7
ajordan6337 is offline
