Help! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-17-2013, 02:50 AM Thread Starter
Help!
I have been running a gearbox tuner on my truck and it has worked great. The other day I saw a ad on craigslist the other week for a H&S pro xt programmer so I bought it and that is where my nightmare starts. The guy told me he had unlocked it from his truck and he didn't when I plugged it to my truck it erased my hole ECM somehow and truck wouldnt start. So after getting my trucked towed to the shop and the ECM reflashed the truck will start again but it won't let me reinstall my gearbox programer. The error code says it can't read the vin. I have talked with gearbox a lot . They have sent me 2 more tuners to try and when I hook them up they give the same code. So with that said I took the truck back and the dealership dump the hole truck and reprogram everything again, still doesn't work. I need it bad because I have removed all the emission on my truck and doesn't won't to run without it . Could the ECM being going bad or did the H&S strew my truck up forever? Help please .
DB64 is offline
post #2 of 3 Old 08-17-2013, 06:08 AM
superduty6.4's Avatar
What kind of truck was the h&s on before yours? Try and update the card using the automatic updater on their website and see if that helps. All the instructions are on their site to walk you through the update process.
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #3 of 3 Old 08-17-2013, 06:14 AM
theplumbingmedic's Avatar
Good advice ,,,,,,hope it works for you OP
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
