Upcoming trip - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-16-2013, 05:48 AM Thread Starter
ATVJOE's Avatar
Upcoming trip
Looking for some advice, my wife and I are heading to Mukwonago, WI. from Kingwood, TX. in the next few weeks. My concerns are that I currently run the H&S mini on the mild settings not the HD I used to run with excellent mileage. This will be a long trip each way and wondering the best setting to have set. The last thing I want, and what worries me is having a problem with the truck on this trip and worry about costly repairs.
I have 123,000 miles on the truck currently and have been programmed and deleted for around 20,000 miles. The truck has been running great in all settings I have tried, and I do not ever really get on the throttle as my butt cringes due to expenses if it breaks.
Any suggestions would be welcolmed.
2008 F250 SD King Ranch 4X4, H&S Mini DPF delete
Job 2 LB SRW Crew Cab AMP Power Running Boards
ATVJOE is offline
post #2 of 15 Old 08-16-2013, 05:56 AM
Quoted: 784 Post(s)
Not familiar with H&S but as with any tuned truck you'll be fine in your daily driver tune or light tow tune(assuming the truck will be loaded with luggage in crap from the wife if yours is anything like mine, )
Corey@CNCFAB is offline
post #3 of 15 Old 08-16-2013, 06:01 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
As long as you are up on the maintenance I wouldn't worry about it. You should be fine
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #4 of 15 Old 08-16-2013, 09:18 AM Thread Starter
ATVJOE's Avatar
Can I run the HD tunes as that gets the best mileage? I keep up on the maintenance religiously, to many other stories scare me.
ATVJOE is offline
post #5 of 15 Old 08-16-2013, 09:29 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Oh yea you should be fine running the HD tunes
08 F350 cc/sb 4X4
post #6 of 15 Old 08-16-2013, 01:20 PM
trip
More to the point. If you have the HD tunes on, you need to pay attention to really steep hills, etc. That is where your motor will get the hard boost, fuel, etc.. If you are just cruzing, no problems because the motor is not gulping down lots of air and fuel. Things like towing with cruise control on a steep hill will allow harsh conditions on the HD tunes, but NO ONE will pass you! . Just pay attention to the conditions around you and you will not have problems. I leave mine turned up because that is where I get the best mileage. If I let my wife drive, I turn it down!
brada is offline
post #7 of 15 Old 08-16-2013, 02:22 PM Thread Starter
ATVJOE's Avatar
Great info, I won't be towing anything except luggage, of coarse the wife will have that area loaded down. Oh and I do all the driving, she won't drive the truck, it's too big.
ATVJOE is offline
post #8 of 15 Old 09-25-2013, 04:29 PM Thread Starter
ATVJOE's Avatar
Well we made the first leg of the trip today and went from Houston to Jacksonville, AR. Averaged 17mpg on the HD300 mild tune, going to Lincoln, IL tomorrow and going to run the Hot D and see if mileage gets better.
ATVJOE is offline
post #9 of 15 Old 09-25-2013, 06:00 PM
WoodBoy's Avatar
No matter how big of a tune you are running, you are not making more power than stock until a certain throttle point if you understand what I am saying? Just most of the time the higher hp tunes make the power more efficiently than the stock and lower tunes, hence the better fuel mileage. I have towed 15k with my 275 tune a number of times. You shouldn't be scared to daily drive your most powerful tune
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #10 of 15 Old 09-25-2013, 06:34 PM
TD-5's Avatar
Quoted: 3 Post(s)
Just for comparision, I did a 2400 mile trip back in August. I Ran through the different HD300 tunes & checked mileage on each during the trip. I got the best mileage on the stock file, but all tunes were within 1MPG of each other. Both times I ran the HD300 stock file my average speed was lower at between 55 & 65 MPH due to road conditions. Tow, Street & Performance tunes were all run on flat prairie highways at 65 to 75 MPH. I wouldn't say weather conditions played into any of the mileage figures, Athough there were times when head winds would have been in the 10 to 15 MPH range.
Truck is 2010 F350 with 3.55 gears & 37" tires. Engine RPM ran between about 1450 & 1700 depending on speed. Speedo is calibrated dead on according to test sections along the highways & about 3 different electronic speed read outs in construction zones. I thought I would see a little higher mileage figures on the flat Alberta Roads, but it is what it is. The only thing I really noticed between the tunes was my back bumper corner was black after running the Performance tune
All the tunes cruising @ 70 MPH ran 13 to 15% throttle, 25 to 30 % engine load, 9 to 12 lbs boost & 640F to 680F on the pre turbo pyro.
Here is what I got hand calculated to US Gallons.
HD300-Stock = Ran 476 miles = 16.39MPG
HD300-Tow = Ran 387 miles = 15.56MPG
HD300-Street= Ran 472 miles = 15.81MPG
HD300-Performance= Ran 325 miles= 15.53MPG
HD300-Stock= Ran 524 miles= 16.45MPG
I ran the last 200 miles home on the Tow tune again but haven't filled up to see what that figured at.
What kind of mileage results do you see with the Mild Group of tunes compared to the HD 300 tunes on your truck?
TD-5 is offline
