****! Rad leak guys come in. - Ford Powerstroke Diesel Forum
post #1 of 19 Old 08-15-2013, 09:01 PM Thread Starter
Clayton1985's Avatar
Just my luck too, Im heading home tomorrow from vacation (1500km, 20hrs ish) and I walk outta restaurant tonight and see a dinner plate sized wet spot under front of truck.
Seems as of now to be a slow leak but I dont know how fast or what this leak is gonna get and If I risk driving home tomorrow. There are hours of no service and un-inhabited areas and im also pulling a trailer w/ corvette on it.
I relieved pressure from degas and will check level in the A.M and make a decision I guess.
Any advice or ideas from experience for me?
Thanks!
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #2 of 19 Old 08-16-2013, 03:28 AM
I had to have the rad replaced 2 weeks ago on my way from Ohio to Florida (halfway), slow leak, I left the air conditioner off and made it to Winter Haven, Fl. I had a case of bottled water and had to add approx a couple gallon. Had the rad and 2 thermostats replaced. $1900.00.
Good luck
Mark
2008 Ford F350 Lariat DRW
All stock
2012 Keystone Avalanche 330re
2007 Harley Davidson Ultra Classic
cmssorrell is offline
post #3 of 19 Old 08-16-2013, 04:34 AM
A dinner plate sized amount over the course of a meal.....That is no slow leak. If you were closer to home, I would push it, but from what I'm hearing you say.....Take your time and get it fixed. I wish you the best of luck. Oh yeah, I'm on my third radiator myself.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #4 of 19 Old 08-16-2013, 06:03 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
So its for sure leaking from the radiator? Are all your radiator hoses the updated ones?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 19 Old 08-17-2013, 07:51 PM Thread Starter
Well it was a wet spot about 6" in diamter, I exagerated a bit with my dinner plate size. It was over the course of 2.5 hrs.
Anyways, I check in the morning (yesterday/friday) and there was very little if any leak, degas was where it was when I parked it. So I began my journey.
I brought a few spare gallons of water and crossed my fingers....I made it home without any leakage.
There was no wet spot on driveway this morning but the frame had some coolant on it right below corner of rad. So its a very slow minor leak as of now.
04hd -- Im almost positive its the rad but I havent got in there real good yet to be 100%. Im not sure on the hoses, if they are the 2 o ring ones or not, I believe they are but again not 100%.
1999 Corvette Cpe
post #6 of 19 Old 08-19-2013, 06:42 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Check to see if the ends of the hoses are white. If they are you have the updated hoses. Hopefully the moshimoto radiator will be released soon!
08 F350 cc/sb 4X4
post #7 of 19 Old 08-19-2013, 11:56 AM Thread Starter
The hose ends are not white. It is 100% the rad leaking as well. I checked with local ford and said not covered by warranty so looks like a mishimoto for me!
1999 Corvette Cpe
post #8 of 19 Old 08-19-2013, 12:09 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yea I would go with moshimoto. I would also change out the hoses to the updated ones with the white ends while your at it. Then you should be good to go!
08 F350 cc/sb 4X4
post #9 of 19 Old 08-19-2013, 01:10 PM Thread Starter
You bet! Ill swap over to the cat elc coolant while I'm at it, been in my basement since winter, lol.
1999 Corvette Cpe
post #10 of 19 Old 08-19-2013, 01:11 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Sounds like a good plan . When I do t stats I am also going to update to the new degas bottle.
08 F350 cc/sb 4X4
