Engine fan - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-15-2013, 08:15 PM Thread Starter
floorboy's Avatar
Engine fan
I got back from a 500 mile trip last week and haven't driven my truck since... Today when I took it out the engine fan came on immediately (it was 68* in the garage).
Truck has 100k on it. Did the clutch simply go out or would something else cause it? I imagine the clutch is just going bad. Thanks.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #2 of 12 Old 08-16-2013, 04:36 AM
Subscribed, mine has done this before too. I've never had a problem. One time, I shut my truck off right away, then I restarted it and the fan was off? Maybe it is just another Powerstroke Gremlin?
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #3 of 12 Old 08-16-2013, 10:39 AM
I don't have the hard answer to this but I can tell you that it seems to be a common thing that happens when our trucks sit for a period of time. I average 2-3 days between drives. As it is not always consistent , when it does happen, the fan will turn off after a few minutes going down the road. It is not "problem" per say. I would worry if the noise doesn't stop. May be a seized fan clutch or something.
2010 F250 HD 47K
DisposableHero is offline
post #4 of 12 Old 08-16-2013, 11:09 AM
Echo's Avatar
Mine does the same thing. Sometimes it will come on when I first start the truck but it shuts off after a few minutes.
Echo is offline
post #5 of 12 Old 08-19-2013, 09:04 PM
tony97gt's Avatar
Mine does this too
2008 F250 Harley Davidson 4x4, Upgraded LED lighting, JL Audio 13.5" Stealthbox, JL Audio C3 door speakers, JL Audio 500.1 for the stealthbox, JL Audio 400.4 for the doors, Viper 5704 alarm/SmartStart and GPS tracker, JimmiJammer door plates, JimmiJammer gateguard, Delete front lock/rear handle swap, DPF delete, MiniMaxx, 2.5" level, Sinister coolant filter, 55w 6000k HID's driving/fog lights, S+B CAI, MBRP 5" DP back exhaust, 35x12.5x20 TIS 20" rims, Nitto Trail Grapplers, adjustable track bar.
tony97gt is offline
post #6 of 12 Old 08-20-2013, 03:48 AM
69Stang's Avatar
Mine runs for about 30-60 seconds and then shuts off. A guy at work had his fan clutch go out completely and the fan stayed on all the time.
2010 F250 Cabela's Edition FX4, 6.4L, 3.55LS.
2011 Palomino Throroughbred 828RLS travel trailer.
"Democracy is two wolves and a lamb voting to have lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
69Stang is offline
post #7 of 12 Old 08-20-2013, 05:26 PM
ATVJOE's Avatar
Mine goes on when I first start off in the morning hitting only 140 degrees, but goes off after about a minute or two. Later I hit 195 and she rarely. Kicks back on. It's a gremlin thing...
2008 F250 SD King Ranch 4X4, H&S Mini DPF delete
Job 2 LB SRW Crew Cab AMP Power Running Boards
ATVJOE is offline
post #8 of 12 Old 08-21-2013, 04:39 AM Thread Starter
floorboy's Avatar
I finally got a chance to driven it more than a block and it did indeed turn off and never ce back on. I'm not gonna worry too much about it for now.
floorboy is offline
post #9 of 12 Old 08-21-2013, 09:29 AM
flashover1969's Avatar
Send a message via Yahoo to flashover1969
The clutch is electronically controlled and its probably some sort of operational check that the ECM does when the truck is first started. Who knows...
flashover1969 is offline
post #10 of 12 Old 08-22-2013, 11:40 AM
Mine does this too and so does my semi-truck with a cummins. I think its like the previous poster said about an operational check the ECM does. I wouldn't be to worried.
Quatris is offline
