New to Me: Starting maintenance - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-13-2013, 09:19 PM Thread Starter
I just purchased an 09 F350 with 93K from a used car dealership. That being said I have no way of knowing what cycle the truck is on for maintenance. So today I did the fuel filters, and changed the oil. I also did the airfilter as it was quite dirty. The front differential will need to be changed soon as it was showing signs of age on the wipe card.
Thanks to the info I found on this forum, it was all fairly straight forward.
boidranch is offline
post #2 of 4 Old 08-13-2013, 10:44 PM
Couch warmer
SchismX's Avatar
I would also do a transmission flush, t-case oil, rear diff, and coolant flush as well. That way you can start completely fresh.
08 F-350 CCSB - H&S Mini Maxx, 5" MBRP straight piped and 3" CAC pipe, Flo-Pro full EGR delete, Spearco IC, AFE STG 2 CAI
SchismX is offline
post #3 of 4 Old 08-14-2013, 05:07 AM
RHKA's Avatar
+1 and make sure your using motorcraft filters as well.
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #4 of 4 Old 08-14-2013, 07:23 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I agree with the above. I would change all fluids and replace with motorcraft filters.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
