Hub issues - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-11-2013, 09:53 AM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
Hub issues
Had a buddy drive my truck home from the dealer and noticed when he followed me my front hubs were spinning. They never spin cause I leave them in auto. I thought maybe they got turned to the lock position so I took my center caps off and they were in auto. I switched them back and forth check the vacuum pump then tried again. Now only the passenger on was spinning. I put it in 4x4 to see if it was working allright and it was when I took it back out of 4x4 with the esof they both stayed spinning even tho 4x4 was off. It's like there stuck in the locked position. Any ideas
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #2 of 6 Old 08-14-2013, 10:05 AM
Quoted: 45 Post(s)
Cycle it a few more times maybe?
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #3 of 6 Old 08-14-2013, 10:57 AM
That is a very common problem…..I personally think the hub set-up on the Super Duties is junk. How many miles do you have on those hubs? You may need to replace them. If your truck is under warranty get them replaced. The hubs are not cheap.
Good Luck!
Turbo Kidd
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #4 of 6 Old 08-14-2013, 02:19 PM
Quoted: 45 Post(s)
Just got mine replaced under warranty with 35k miles last week. Got a new solenoid as well. I have a feeling they were stuck engaged before they were replaced. What are you looking at when you say you could see them spinning?
post #5 of 6 Old 08-15-2013, 04:04 AM
muntu's Avatar
HUBS SPINNING ? does that mean the front drive shafts ? i don't get the hubs part.
so to test if the esof is behaving properly do you have to jack up the front end and get both wheels off the ground ?? if so guess you need a stout jack...which I don't have.
I have noticed on my front wheel rims have a lot of dirty oily stains...don't know if that is road grime or an issue...the back wheel chrome is clean.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #6 of 6 Old 08-15-2013, 07:05 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
When my front wheels had grease on them it was from a tie rod end boot that tore and was throwing grease on the rims.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
