maching 6.4 heads yes or no? - Ford Powerstroke Diesel Forum
View Poll Results: Machining 6.4 heads yes or no?
yes 3 75.00%
no 1 25.00%
Voters: 4. You may not vote on this poll
post #1 of 4 Old 08-11-2013, 09:26 AM Thread Starter
wondering if the 6.4 head should be machined (i know ford says a no no for this) but it seams to work for the 6.0 liter, i know valves seats can be receded back into the head but what about the glowplu and the injector tip can they become in contact with the pistons? because they technicaly will sint lower in the combustion chaimber?
goldgoose is offline
post #2 of 4 Old 08-12-2013, 10:15 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I am curious as well. I'm in for results!
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 4 Old 08-15-2013, 09:38 PM Thread Starter
bumped bumped
post #4 of 4 Old 08-23-2013, 07:44 AM
I got my heads machined when doing studs and did not do the valve seats or worry about anything else and everything has worked out great. One head was slightly out of spec and the other was just under spec so i got them machined as to not take a risk. If not getting them machined at least get them checked for cracks and if they warped.
lazlow is offline
