a/c issues - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-04-2013, 10:12 PM Thread Starter
a/c issues
I have a 2008 ford f250 , and the a/c stopped working! when I turn it on it blows hot air both in max a/c and regular. is not dual climate , sometimes the blower motor stops altogether. any ideas ?
brewcrew82 is offline
post #2 of 8 Old 08-05-2013, 11:01 AM
RHKA's Avatar
Is the clutch on the a/c compressor activating?? And the blower motor is a separate issue, might be bad resistor, or a short, or even a bad ground.
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #3 of 8 Old 08-05-2013, 11:03 AM Thread Starter
Unsure about the compressor clutch !
post #4 of 8 Old 08-05-2013, 11:57 AM
RHKA's Avatar
Well you might want to check that out. With your engine running and a/c on, open your hood and if your clutch on your compressor is engaging(it should make like a clicking sound every 2-5 seconds or so) if it is you know your compressor is working, then you most likely losing fluid some where, then you need to determine where it's leaking from, fix the leak and recharge.
6" FABTECH LIFT
RHKA is offline
post #5 of 8 Old 08-05-2013, 12:54 PM Thread Starter
I think I have it narrowed down to my blend door , but unsure . How would I know ?
post #6 of 8 Old 08-05-2013, 01:19 PM
RHKA's Avatar
Testing the actuator with a volt meter. If it has proper voltage, you know it's a faulty blend door actuator.
6" FABTECH LIFT
RHKA is offline
post #7 of 8 Old 08-05-2013, 02:42 PM Thread Starter
The only reason I ask is I dont hear it switch from air to hear ! Am I wrong ?
post #8 of 8 Old 08-28-2013, 11:10 PM Thread Starter
Well it was my blend door !!
