Considering 09 f 450 purchase - need advice - - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-03-2013, 04:01 AM Thread Starter
Hi,
I'm looking at a 2009 f450 lariat. It has about 14000 miles. Looks totally stock. Truck runs and drives great! What kind of maintenance issues would I need to address? Are new tires and batteries a consideration given that they are original? What else should be done to "baseline" the truck?
Thanks in advance!!
Matt
Cheepjeep80 is offline
post #2 of 15 Old 08-03-2013, 06:32 AM
matted2thefloor's Avatar
Unless its already been done and can be verified, change the oil, fuel filters, check the air filter, check the coolant level and test the nitrite levels. Tires would probably be OK, but I'd still look at the date of manufacture on them to determine that for sure. DOT states 5 years life on a tire...if memory serves me right!
Highly recommend a CARFAX report and have your local Ford dealer show you the Oasis report too.
Good luck!
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #3 of 15 Old 08-03-2013, 07:54 AM Thread Starter
Thx!! Carfax looks good. Is there a test kit for the coolant? What about the batteries? Have new ones installed or just roll with them?
Matt
Sent from AutoGuide.com App
post #4 of 15 Old 08-03-2013, 08:56 AM
theplumbingmedic's Avatar
Wow thats some low mileage!!! Do you mind posting what they are asking for it? Color, options ect.
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #5 of 15 Old 08-03-2013, 09:11 AM Thread Starter
They are asking $37k. I think the link to the window sticker is below.
http://fordlabels.webview.biz/webvie...xw43rx9ea75626
Thx!
Matt
post #6 of 15 Old 08-03-2013, 09:17 AM
That looks great. Do yourself a favor a look up the thread General 6.4 modifications country aggie did a great write up, if you are not well informed on the 6.4.Good luck i hope you get it
Mike
exhaust
post #7 of 15 Old 08-03-2013, 09:16 PM
RHKA's Avatar
Matt
You can get some from your local Napa. Or you can order the Ford Rotunda from Acustrip it's about $5, for a pack of 4 and the testing key to match, plus shipping. Best $5 you can spend to determine if the truck is worth the money. But at that mileage I highly doubt you have anything to worry about, unless the previous owner totally dropped the ball and didn't change absolutely nothing. Goodluck man.
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #8 of 15 Old 08-03-2013, 09:23 PM
I wouldn't pay $5 for it until I saw an oasis report. Glwb!!
Moto2four is offline
post #9 of 15 Old 08-03-2013, 09:30 PM
RHKA's Avatar
True, but if your serious about getting a 6.4 your going to need them sooner or later. And as far as the batteries I wouldn't swap em until they give out, use that money for something else.
6" FABTECH LIFT
RHKA is offline
post #10 of 15 Old 08-04-2013, 08:21 AM Thread Starter
Thanks for all the replies!!! I picked up the truck last night. It is awesome!!!!
Considering 09 f 450 purchase - need advice --imageuploadedbyautoguide1375633260.161611.jpg
