gutted DPF - can you run it with out the delete tune? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 08-02-2013, 01:05 PM Thread Starter
Vodka0tter's Avatar
Saw a thread on folks gutting the DPF/Cat and running it as opposed to a delete pipe. I am considering doing this but modding an assembly to a 4" in/out since it looks factory.
My question is if all the sensors are intact, can you run this set up with no tune for an emissions test? If there is no problem, could you run a DPF delete with sensors in and no tune? I have a guy that dosent care how it looks as long as the computer likes it...
I would put a stock tune back in so the EGR works for testing.
Vodka0tter is offline
post #2 of 13 Old 08-02-2013, 01:11 PM
BIG Laing's Avatar
Yeah it works great! There is no need to be dumb like the rest of us and buy a tuner. We like to waste money!
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 13 Old 08-02-2013, 01:16 PM
Gotta have a delete capable tuner, even if you run snake oil in your fuel tank.
Moto2four is offline
post #4 of 13 Old 08-02-2013, 10:57 PM
RHKA's Avatar
now, now be nice. You can run it stock, without DPF, just make sure you got an extra $15k or so laying around.
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #5 of 13 Old 08-03-2013, 03:42 AM Thread Starter
Vodka0tter's Avatar
I have an H&S tuner that I am currently running with the delete pipe set up. Guess I worded my question wrong...
If I run a gutted DPF with the sensors in place and remove the off road tune, put it back to stock for inspection (so it activates the EGR) will I have problems?
Should I just swap out the delete pipe with the non-tampered DPF and remove the off road tune for inspection.
post #6 of 13 Old 08-03-2013, 04:25 AM
Echo's Avatar
Yes
I would go with this unless you like large repair bills
Echo is offline
post #7 of 13 Old 08-03-2013, 05:00 AM Thread Starter
Vodka0tter's Avatar
Gottcha. Thanks!!
post #8 of 13 Old 08-05-2013, 05:59 PM
theplumbingmedic's Avatar
I didn`t see the sign smart azz`s please post here . At least you got an answer though
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
post #9 of 13 Old 08-05-2013, 06:04 PM
BIG Laing's Avatar
post #10 of 13 Old 08-05-2013, 06:18 PM
sending you a pm Laing
exhaust
