Need cryo rotor pics please - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-01-2013, 06:42 PM Thread Starter
I ordered some power slot cryo rotor and what seems to me like how they should be mounted for the passenger side has an L sticker on it to dissipate heat out away from the rotor as it spins. I don't have the other rotor due to them sending me the wrong one which the correct one is on its way to make a long story short. I was just wondering if anyone that has these rotors on their truck could send a pic of the passenger or drivers side?
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #2 of 7 Old 08-01-2013, 06:53 PM
I've got the non cryo powerslots. I'll get pics and post them in the morning.
Moto2four is offline
post #3 of 7 Old 08-01-2013, 07:08 PM Thread Starter
Thanks. I just ordered rears first because that's what I needed to replace but the packaging is all messed up with different labels. Customer relations took care of the issue and is sending me the right stuff. I then said screw it and ordered the front brakes later so everything matches. Waiting for the fronts to come prob tomorrow and then I'll see if those are right or not.. It's all good though
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #4 of 7 Old 08-02-2013, 06:13 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
I am interested to hear how the powerslots compare to the factory rotors. When I do brakes I am not sure what to go with. Are you going with the OEM pads or hawk pads?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 7 Old 08-02-2013, 06:28 AM
Snake's Avatar
Quoted: 47 Post(s)
I remember installing my Powerslots and thinking I had them backwards. Are yours labelled like these?
E90 330i Centric Power Slot rotors - rear -Sports Package 2006
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
post #6 of 7 Old 08-02-2013, 07:01 PM Thread Starter
I'm going with ebc green stuff 6000s in the rear and 7000s up front.
Yes that is how they look backwards but there is an install sheet I found that verifies that they're labeled correct. I also talked to a rep that furthered they are right based on the stamped number on the rotor itself. They said most of their rotors are made in the "correct" way that the slots go, and some of them are made "backwards" like the ones for my super duty. Don't know about other model years though. And they said the main thing is depending on internal vein construction. I will put them on the correct way even though it'll seem to others that I don't know how to install rotors.
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #7 of 7 Old 08-02-2013, 07:03 PM Thread Starter
Now just waiting on my other rear rotor and front pads to come.
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
