no compression on cylinder #4 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-01-2013, 04:26 PM Thread Starter
Unhappy no compression on cylinder #4
I have a 2010 F350 with a 6.4, it has no compression in #4 cyl. Well it has very low about 45 psi vs 300 on the rest of cylinders, debating wether to take it apart and check buned valves or pistons. Any ideas before I do that?
Any help will be appreciated, Thks
A&KTREJO is offline
post #2 of 7 Old 08-02-2013, 04:26 AM
Quoted: 2 Post(s)
is it under warranty?
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #3 of 7 Old 08-02-2013, 05:40 AM
Is it stock, or is it deleted? What happened? How many miles? My guess is you melted a piston.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #4 of 7 Old 08-02-2013, 06:18 AM
WoodBoy's Avatar
My guess is you cracked a piston
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 7 Old 08-07-2013, 05:21 PM Thread Starter
good guess I tore it apart and have 2 cracked pistons and one melted, now I wonder what caused the failure?
A&KTREJO is offline
post #6 of 7 Old 08-07-2013, 05:42 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Hard to tell what caused the problem with such little info you provided... Even then it will still be a guess but at least with more info it would be an educated guess! Sorry to hear, good luck with your repair. Hopefully your under warranty still.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #7 of 7 Old 08-08-2013, 04:38 AM
Were you running on of those crazy tunes like +210HP?
I hope so because then it's just your fault. If not then what caused this is unknown.
I'm actually happy when sometimes because breaks because of my doing. When it's not then I get concerned.
Hope the cost of the repair is not too much.
Dang that's just a bummer.
GSchretter is offline
