Temp issues while towing - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-31-2013, 11:26 AM Thread Starter
kcschultz's Avatar
Hey everyone, I am at a little bit if a loss so I thought I would throw this to the forums.
I have an '08 F250 6.4 Crew Cab 4x4, DPF deleted, spartan tuned 125 hp early lock. When hauling my RV (bumper pull 10,500 GVWR) this past week, I was seeing EOT and ECT of 235 or better on hills and the truck seemed to be struggling. At the same time boost was 30 - 40 psi constantly but would go back to between 10 -20 psi on flat ground.
Does this sound normal? I am mildly concerned about the temps since the dash needles never moved off center. I have always felt I had plenty of truck for this rig, I hope I'm not wrong.
I have rear airbags to help with the rear sag once hooked up to the RV, should I look at a different rear end gear, I am running the stock gear.
Any input would be great!
kcschultz is offline
post #2 of 9 Old 07-31-2013, 12:07 PM
08KingRanch350's Avatar
I just pulled mine this past weekend same weight of trailer and I also have the Spartan but I use the 210 tow performance tune early lockup and never got over 210 on eot or ect. My two cents is try the tow tune.
08KingRanch350 is offline
post #3 of 9 Old 07-31-2013, 01:16 PM
macgyvr's Avatar
How big of hills?
If you can see the pic in my sig I've pulled it all over the country. My coolant temps have got to 225 on some hills when I'm really wailing on it and my boost has got to 30+ psi
I haven't looked at oil temps. I have a trip this weekend, I'll try to remember to turn that monitor on this weekend.
I run the mild tune on the h&s.
If the hills are decent I would say that your temps aren't too out of control, but if they aren't that big...there might be another issue based on the numbers I've seen.
mac 'usually grossed out about 26k' gyvr
2008 F350 Lariat 6.4 dieselcrew cab dually 4x4 4.10s 135k
DPF/Cat/Muffler delete, AFE air box, H&S minimax, B&W goose, Tinted Windows, air bags, procomp traction bars
"Fight socialism buy a FORD"
macgyvr is offline
post #4 of 9 Old 07-31-2013, 02:38 PM
44magnum's Avatar
I had my truck overheat with my 38' gooseneck in the Texas hill country, which is very hilly at relatively low speeds, some stop and go ect. I'm not sure what it weighed, 12K, 14K maby more. And it was about 102F out. I had to pull over and let it cool off, them I drove easier and didn't have anymore trouble.
I would say that seems a bit warm but it depends how you were driving it, how bad were the hills and how hot it was outside. Also you said your truck was struggling, I would say it shouldn't be, but it really depends on your definition of struggling.
The boost seems about right. What oil and coolant temps do you usually see, just driving around without a trailer?
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #5 of 9 Old 07-31-2013, 04:16 PM Thread Starter
kcschultz's Avatar
Typical oil and coolant temps are right around 200, no more than 205. Hills were fairly good grade, 2.5% maybe.
08KingRanch350 : I will try the tow tune. Was it stock on your spartan or did you download it from somewhere?
post #6 of 9 Old 07-31-2013, 04:59 PM
Water temp
I pulled 5 ton the other day at 70 in 90 degree temp and the gauge diden't move. I really need to put some aftermarket gauges on this thing.
indian347 is offline
post #7 of 9 Old 07-31-2013, 07:39 PM
I pull a 8k bumper tow camper and pulled it up some 8% grades last weekend and didn't see my dash gauges move but my ect climbed up to 220 and my eot climbed to 230 or so. I have an H&S black maxx with gearhead tunes and I run it on no power which is 50hp. Ford says that is ok but I also would like it to stay cooler
08 F350 CCSB Lariat
H&S Black Maxx
5" Flo pro exhaust
Flo pro egr delete
MBRP Downpipe
MBRP CAC tube
JustinIDFarmboy is offline
post #8 of 9 Old 08-01-2013, 04:29 AM
muntu's Avatar
your temps are totally ok,but tow tune is what you will be safe with....you don't want your temps to go over 235, which they will on steeper terrain if you don't use the tow tune.....just remember this is severe service...you need to change oil at 5k...you didn't give egt's....things get real hot if not in tow tunes.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #9 of 9 Old 08-03-2013, 05:38 AM
rt_hawk's Avatar
I believe that ford says oil temps around 240* are the limit for the 6.4...not the metal parts, they can handle much higher, but the oil will break down and offer less and less protection...240* is a pretty safe estimate of a max oil temp. My truck has hit 220-225 pulling another crewcab truck on my big flat 5er doing 70-75 on a 100* day up a steep grade with a really annoying headwind...
EDIT: 220-225*F oil temp, my coolant was at 203*F
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
