Unsuccessful Fuel filter change... need advice - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-30-2013, 04:25 PM Thread Starter
Attempted to change fuel filter that's located under the truck. Tried to drain fuel filter (using fuel/water separator) it would not stop draining. I figured I drained at least 3 gallons, maybe more. On my previous 6.0 I'd drain about a gallon and it would dry up.
Well anyway I gave up. How much fuel should drain before it is emptied? I had a full tank of fuel would that be a problem.
Thanks for any suggestions,
Mark
2008 Ford F350 Lariat DRW
All stock
2012 Keystone Avalanche 330re
2007 Harley Davidson Ultra Classic
cmssorrell is offline
post #2 of 8 Old 07-30-2013, 04:29 PM
NVHunter83's Avatar
Try loosening the top one just a little. Then drain the bottom one through the valve. Should empty out and then you should be good to go.
2008 Ford F-350
6.4L Power Stroke
Crew Cab Long Bed
Buck Stop Bumper w/
WARN 9500 lbs. Winch
H&S Mini Maxx w/ homemade mount
5" Flo-Pro DPB exhaust w/ muffler
Bilstein 5100s Shocks
AFe Stage II Magnum Force Intake
NVHunter83 is offline
post #3 of 8 Old 07-30-2013, 04:35 PM
diesel23's Avatar
Quoted: 9 Post(s)
Feedback Score: 14 reviews
You want to do both fuel filters , as stated loosen the top filter , you should only have pet **** on bottom open for a few , i just screwed filter with a bucket under and make a swap , just remember to cycle ignition about 6 times before starting to purge air out of system
diesel23 is offline
post #4 of 8 Old 07-30-2013, 06:33 PM
srjd's Avatar
Quoted: 2 Post(s)
Best way to do it is park on a little incline with your low fuel light on. That's how I've done it and no fuel bath and maybe drains for 20 seconds. I've read with a full tank on flat ground it will create a vaccuum and keep draining
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 8 Old 07-31-2013, 03:12 AM Thread Starter
Thanks all......
Mark
All stock
post #6 of 8 Old 07-31-2013, 04:15 AM
RHKA's Avatar
+1 I usually lift the front end up a bit with a full tank and it eventually clears out without losing to much fuel.
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #7 of 8 Old 07-31-2013, 06:25 AM
Do it when your tank is under 1/4 full.
B. Adams is offline
post #8 of 8 Old 07-31-2013, 06:54 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Cycle the key for 30 seconds Atleast 6 times. I usually do 8 times just to be safe.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
