P0625 & Battery light came on - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-30-2013, 03:12 PM Thread Starter
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 7 Post(s)
Feedback Score: 12 reviews
Got the code a week ago, cleared it then it came back on today. Battery voltage while idling ranges from 12.8 - 13.3 volts, and driving under a load it's 13.8 -14 volts. No lose connections or corrosion on connections.
Is my alternator on its way out? Or are the batteries about to crap out?
Sent from AutoGuide.com App
Marshall
2002 F250 7.3L CCSB 4WD
Tinted | Focal speakers & 12" Kicker | CTS Insight | CNC fuel line kit | PIS 200/80's | KC38R | Nathan P3 train horns & Onboard Air
mts678 is offline
post #2 of 11 Old 07-30-2013, 03:22 PM
Are your batteries the originals?
Tjmaxx is offline
post #3 of 11 Old 07-30-2013, 03:31 PM Thread Starter
mts678's Avatar
Quoted: 7 Post(s)
No they came on the truck, and normally the date is on the battery somewhere but nothing visable but they look fairly new, had the truck about a year.
Marshall
mts678 is offline
post #4 of 11 Old 07-30-2013, 05:28 PM
diesel23's Avatar
Quoted: 8 Post(s)
Feedback Score: 14 reviews
Mts , yes i believe your batteries are going , i threw a brake code but it was batteries
diesel23 is offline
post #5 of 11 Old 07-30-2013, 05:35 PM Thread Starter
mts678's Avatar
Quoted: 7 Post(s)
Ok, damgit. I know I can search and read countless threads- but what's a good replacement battery? I have a buddy who works for Interstate Batteries so I can get my hands on just about any brand and type.
Marshall
mts678 is offline
post #6 of 11 Old 07-30-2013, 07:11 PM
___________________________________________
Likely batteries, Check you voltage with engine not running. You are reading alternator voltage with the engine running.
Engine off battery voltage should be over 12V. If you read less disconnect the ground on the drivers side battery and check voltage on each battery separately. in several cases I've seen one battery read low between 7-10v and the other battery read good 12V.
Also you can take your truck to a Wallmart service Center and they will check each battery and give you a print out showing condition of each battery. Takes about 5 minutes, they disconnect ground at each battery. They don't charge for test even if you don't buy there.
2008 F350 6.4 4x4 DRW CC 4:10 King Ranch Job3
Max2006 is offline
post #7 of 11 Old 07-31-2013, 09:09 AM Thread Starter
mts678's Avatar
Quoted: 7 Post(s)
Ok I checked the batteries today with my volt meter with neg and pos leads disconnected- 12.74 volts both batteries. I scuffed up the battery terminals and the connections. The light hasn't came back on yet.
On a good note my buddy at interstate can hook me up with new batteries for $80 for 2 new batteries! So I'm gunna get the new batteries anyway just because the price is insane and I don't know the age of my current batteries.
Marshall
mts678 is offline
post #8 of 11 Old 07-31-2013, 09:25 AM
macgyvr's Avatar
I had one bad battery kill my truck. The other one was good, but the bad one was sucking the life out of the good one.
mac 'replaced them with yellow tops' gyvr
2008 F350 Lariat 6.4 dieselcrew cab dually 4x4 4.10s 135k
DPF/Cat/Muffler delete, AFE air box, H&S minimax, B&W goose, Tinted Windows, air bags, procomp traction bars
"Fight socialism buy a FORD"
macgyvr is offline
post #9 of 11 Old 07-31-2013, 10:55 AM Thread Starter
mts678's Avatar
Quoted: 7 Post(s)
How you like them yellow tops?
Marshall
mts678 is offline
post #10 of 11 Old 07-31-2013, 01:09 PM
macgyvr's Avatar
I've had them over two years now. They have been great. Truck sits for up to a month at a time in the winter and it always fires right up. I run optimas in all my vehicles average about 7 years out of them.
I order them online from advanced auto and get 20% off for just buying online (and sometimes get a $50 gift card) and then pick them up in the store. It saves quite a bit.
mac 'so far so good' gyvr
macgyvr is offline
