Transmission Flush Advice - Ford Powerstroke Diesel Forum
post #1 of 17 Old 07-28-2013, 06:39 PM Thread Starter
Looking at doing a transmission flush on my automatic f250. I want to run Royal Purple in it but don't know if the factory ford stuff is just as good.
Also should I get it done at a 10 min oil change place or bring it right to the dealer?
Trouble maker is offline
post #2 of 17 Old 07-28-2013, 07:05 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
I think your only supposed to run ford sp or lv fluid. I think my dealer gave me sp when I did mine. I definitely wouldn't go to one of those 10 min oil change places. Take it to ford or do it your self. All you need is 10 quarts and the filter or filters depending which filter set up your truck came with. When you drop the pan the gasket is reusable and just make sure ya clean the little shavings off the magnet in the pan.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #3 of 17 Old 07-28-2013, 07:08 PM
jesilvas's Avatar
Quoted: 2 Post(s)
I've done them correctly at those "10 min" places. However, I don't want to do a 5R110 again. They are thermostatically controlled to warm up fluid.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 17 Old 07-28-2013, 07:36 PM
travisH3's Avatar
Quoted: 2 Post(s)
I just warmed mine up. Drained it. Replaced filter. Cleaned out the pan and slapped it back together. Not too bad to do
T-rav
2010 F350 6.4-
travisH3 is offline
post #5 of 17 Old 07-29-2013, 07:41 AM Thread Starter
If I was just doing the pan I would but I want to flush it. They tap into the transmission lines and pump/suck the fluid out while putting new stuff in. Only a small portion of transmission fluid is in the pan.
post #6 of 17 Old 07-29-2013, 07:44 AM
DoubleDpsd's Avatar
Skip the royal purple and take it to a reliable shop with a heated flush machine.
2003 centennial edition f250 4x4 ccsb auto w/blackwater long block w/arp's, 4" exhaust, airaid intake, ODawg's manifold, itp's reg return, sap modified solenoid, DC power 185amp alt, motorcraft 850cca, Warn Hubs, RS 55w 6k hid's, harley headlights, bpd 58v 6 phase, bpd water pump, dieselsite coolant filter, elc coolant, php gryphon, Xcal2 w/unlimited tow, new hfcm, glowshift fuel psi gauge, icon level kit, 20" kmc hoss, 305/55 terra grapplers TOTALED
DoubleDpsd is offline
post #7 of 17 Old 07-29-2013, 07:45 AM
International Threat
Marty's Avatar
What the OP is wanting to do is not the same thing you are reffering to.
Take it to the dealer or take it to an independent shop that has a trans flush machine that can heat the fluid. The trans needs to be up to temperature since they are thermostatically controlled.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #8 of 17 Old 07-29-2013, 07:47 AM
Quoted: 770 Post(s)
X2 on skipping the royal purple but don't do a flush. Brian at BTS says to never do so. Just do the filter and replace what was drained from the pan.
Corey@CNCFAB is offline
post #9 of 17 Old 07-29-2013, 08:25 AM Thread Starter
Why the hate on RP? I would much rather have a top of the line fluid in the tranny.
post #10 of 17 Old 07-29-2013, 08:45 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Get Schaeffer's then, not RP. RP is a big marketing scheme.
BTS uses Schaeffer's.
4R100, 2wd
330,000 + miles
jesilvas is offline
