Where's the port to charge the A/C? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-28-2013, 12:10 PM Thread Starter
I need to charge my a/c and found the larger port in the system but can't find the lower pressure smaller port to hook the recharge can up to? Is it behind the air box?
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #2 of 10 Old 07-28-2013, 12:34 PM
I can't help but I also need to charge my ac, can you explain how to do it?
Tjmaxx is offline
post #3 of 10 Old 07-28-2013, 01:42 PM Thread Starter
Once you find the low pressure port hook the can or refrigerant to it via the quick connect fitting. Start the truck and turn on max a/c. Open the can of refrigerant and it will empty into the system. There is a gauge to show how much is being put in. When the gauge reads you have enough shut the can up and disconnect. Done. Well from what I understand. I just need to find the right fitting to hook up to. There are two and both have different sized fitting so the can only fits onto the right one....and we'll I can't find it :/
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #4 of 10 Old 07-28-2013, 05:21 PM
44magnum's Avatar
Quoted: 2 Post(s)
Ya, its hidden behind the airbox. Tricky to get to, I had to take my airbox out, connect to the fitting, then reinstall the airbox so I could run the truck. take the airbox out and you'll find it.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #5 of 10 Old 07-28-2013, 07:46 PM Thread Starter
Thanks magnum, I was wondering that. Just hadn't had the time to tear it apart.
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #6 of 10 Old 07-29-2013, 09:09 AM
WoodBoy's Avatar
I wouldn't go through the hassle of putting my airbox on to start the truck for the a/c
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #7 of 10 Old 07-29-2013, 05:21 PM
44magnum's Avatar
Quoted: 2 Post(s)
Well, knowing my luck if I had left the airbox off a local squirrel would have gotten its nuts sucked up by the turbo. But that's just my luck.....
44magnum is offline
post #8 of 10 Old 07-20-2014, 05:10 PM
I'm going to do this next weekend I think. Wish I would have done it when I installed me s&b intake.
Tjmaxx is offline
post #9 of 10 Old 07-21-2014, 08:05 AM
Quoted: 3 Post(s)
Yeah it's behind the airbox against the firewall. You should be able to just remove the airbox cover and that should give you enough room. This is assuming you have the stock box in there. No telling about aftermarket as they are all constructed differently.
H&S Mini Maxx
Flo Pro EGR delete
Flo Pro 5"
Flo Pro cold side IC
Rudy's HD pipes
KMC XD125 18"
Nitto Trail Grappler 35x12.5
The_JRuss is offline
post #10 of 10 Old 07-22-2014, 06:41 AM Thread Starter
Yeah, did this a while back. Had to remove my s&b to get to the port. Thanks
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
