Aux back up light wiring question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-27-2013, 11:03 PM Thread Starter
I'm going to install some led lights to point out the back of my truck. A question for the electronic gurus out there, when wiring to an outfitter switch on my dash can I just run a wire straight to the switch or do I have to have a fuse between the lights and the switch? Also which one should I use, currently none of the switches are being used? I heard that they have different watts. Thanks
08 F350 crew 4x4
H&S mini, Sinister egr delete, cold side pipe, 5" straight pipe, S&B intake, 3.5" level, Newton bars, coolant filter, 325's duratracs, ARP studs, 6.0 manifolds, flow pro DP, Detroit truetrac, triple disk converter, led bed lights
79 F350 4x4 460ci
blk450er is offline
post #2 of 11 Old 07-27-2013, 11:10 PM
TheFordman87's Avatar
I cannons tell you about watts difference in the switches. I dont believe I've ever heard about that. But I would assume each switch has a fuse but if your wiring lights from the back of your truck to the switch you need to put a fuse somewhere back there cuz your always suppose to put a fuse outside of the truck.
I'm addicted to diesel and I step on it constantly!
TheFordman87 is offline
post #3 of 11 Old 07-27-2013, 11:10 PM
KCCO!!
kells17's Avatar
Not sure what the 08's run for watts on the upfitters, but as long as the load from the lights do not exceed the watts for the upfitter you choose, you shouldn't have to run an in-line fuse. I didn't and mine work great, I have four mounted underneath my bumper and have never had an issue and barely draws power even with the truck not running.
Edit: I do have a fuse running on mine! Sorry I lied!
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #4 of 11 Old 07-28-2013, 05:21 AM
Term3's Avatar
Quoted: 2 Post(s)
Why not just tie them into your reverse lights with a relay?
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #5 of 11 Old 07-28-2013, 09:19 AM
44magnum's Avatar
Quoted: 2 Post(s)
here is the setup guide for the 08's
I believe the 09+ were slightly different.
upfitter switch setup.pdf
I have my backup lights wired into my stock reverse lights so they go on automatically when I put it in reverse, but if you want to hook them to the upfitter, just run a wire. The upfitters are run through relays so I dont see any need for a fuse, but it wouldn't hurt anything to throw one in while your running the wire. You will want to know what amperage of the lights your installing so you can wire it to an appropriate switch.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #6 of 11 Old 07-28-2013, 11:49 AM Thread Starter
Ok that's guys. I don't want to wire them into the reverse lights because I don't want them to come on all the time every time I back up. Plus if I want to have them on while I'm outside the truck I want to be able to control them. I just thought a while ago I read something that two of the switches had a different wattage than the other two. I will probably put a fuse in just in case for cheap insurance I guess.
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #7 of 11 Old 07-28-2013, 02:16 PM
RHKA's Avatar
I think your right, I think number 1 & 2 upfitters are 30 amps, 3 is 15, and 4 is 10. I'm not 100% sure so don't quote me. Can someone clarify this??
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #8 of 11 Old 07-28-2013, 05:18 PM
44magnum's Avatar
Quoted: 2 Post(s)
According to previously attached file (see my first post), number 1 & 2 are 30 amp, 3rd is 10 amp and 4th is 15 amp.
44magnum is offline
post #9 of 11 Old 07-28-2013, 08:06 PM Thread Starter
Ok, quick conversion question. If I use two 15w led lights 30w total, what would that convert into amps for which up fitter?
08 F350 crew 4x4
79 F350 4x4 460ci
blk450er is offline
post #10 of 11 Old 07-28-2013, 08:13 PM
crash&burn's Avatar
I belive its 2.5 amps. 12volt system 30 watts 3012=2.5 amps
Shawn
2004 CC F350 - 4-5" exhaust no cat - CTS Insight with turbo timer and Egt's - EGR Delete - K&N - Coolant Filter
SCT with Custom Tunes - MTW MadMax - 190/Stock - PTP Solenoid - Blue Spring - A few mystery switches
crash&burn is offline
