Keeping the fog lights on with high beams? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-26-2013, 04:38 PM Thread Starter
Trigger01's Avatar
I was wondering if there is a modification I can do to keep my fog lights on with my high beams? I did a similar mod to my '01 Ranger. It was pretty simple, all I had to do was bend a tab on a fuse/relay. I have looked around but couldn't find any info about doing this to Super Dutys. Has anyone ever done this or heard of this being done?
Mike
2008 F-350 Lariat 4X4 CCSB
Trigger01 is offline
post #2 of 14 Old 07-26-2013, 06:13 PM
44magnum's Avatar
Quoted: 2 Post(s)
No modification I know of. Only thing I know of is a brite box. Innova Design & Distributing, Inc. - The Brite Box, Bulbzilla / Fogzilla, Diesel Turbo Lifesaver, Eclipse Sun Shade
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #3 of 14 Old 07-26-2013, 07:12 PM
Koda22's Avatar
Quoted: 5 Post(s)
I did this on my old Colorado, really makes a difference...wish I could do it on my 6.0
Koda22 is offline
post #4 of 14 Old 07-28-2013, 06:59 PM
rt_hawk's Avatar
I bought a kit off eBay for $25 bucks that's works awesome, the wiring diagram it came with is pretty generic and from for a 99-03 7.3....but using a test light I figured out my truck easy enough, just search for 2008 F250 high beam on eBay and you will see it...sold by highbeamkits I believe. Pretty nice kit I thought...
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #5 of 14 Old 07-31-2013, 07:13 AM
Beef52751's Avatar
I did it on my 03. There was a write up on it somewhere on here. All I had to do was cut and ground 1 wire
2006 CCSB F-250 King Ranch FX4 6.0
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
Boost, Pyro, and Fuel Pressure Gauges
Beef52751 is offline
post #6 of 14 Old 08-01-2013, 05:22 AM
countryboy73703's Avatar
Quoted: 2 Post(s)
I was just thinking this at 530 this morning... i coul def figure out a way to do it, but I'd be running wires and relays everywhere..lol but I'm not going it that way... so I guess i"ll just wait patiently to see if anybody generates alternate ideas.
countryboy73703 is offline
post #7 of 14 Old 08-01-2013, 09:24 AM
kevinah's Avatar
Mike
Not sure if you have them already on the light switch or not. I didn't have them. So, I bought the lights and hooked up to #1 upfitter switch. They come on whenever I flip the switch.
kevinah is offline
post #8 of 14 Old 08-01-2013, 10:33 AM Thread Starter
Trigger01's Avatar
I do already have the factory switch. The truck is a Lariat so not much needed(s) to be added.
post #9 of 14 Old 08-17-2013, 05:32 AM
Quoted: 2 Post(s)
I also have them from the factory... nobody seems to have any input on an easy way to do this... maybe we could look back for a previous super duty and figure out something for the 6.4's
2008 f250 fx4 crew,spartan tuned running 250hp, dpf/cat removed with 4" turbo back, RCX 3" lift, 35's on stock 18's (for now), and lots more in the near future
Active Duty Navy, Machinest Mate
post #10 of 14 Old 08-18-2013, 03:16 PM
tracymangus's Avatar
The easy way to make this work... put a Diode between the High beam power wire and the fog light power wire. so that the power from HI beam will send power to fog lamps, but the power from fog lamps will not back feed to the High beams.
:drive:
tracymangus is offline
