EBP at idle? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-26-2013, 12:52 PM Thread Starter
EBP at idle?
What should my ScanGuage 2 be reading for ebp at idle? All Stock.
Austin351 is offline
post #2 of 11 Old 07-28-2013, 07:01 PM
rt_hawk's Avatar
14.7 + 2.0-3.5 give or take...
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #3 of 11 Old 07-28-2013, 08:45 PM
srjd's Avatar
Quoted: 2 Post(s)
I think my mini Max reads 3 at idle
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 11 Old 07-29-2013, 07:20 AM Thread Starter
I'm reading about 17 at idle. Didn't know if the ScangaugeII accounted for the 14.7 or not. Sounds like the mini maxx does.
post #5 of 11 Old 07-29-2013, 07:27 AM
srjd's Avatar
Quoted: 2 Post(s)
My barometer reading says 12 no matter where I am. Ebp always 3 at idle
srjd is offline
post #6 of 11 Old 07-29-2013, 07:35 AM
08PowerstrokeFX4's Avatar
On my Edge CTS (which i only use for monitoring) readys 3 at idle.
F250 CCSB 6.4L Powerstroke
Spartan Tuned, ATS Trans, Sinister Diesel Goodies, Elite Diesel Goodies, and a bunch under the hood.
We miss you Ron. Thanks for everything you did for us and sharing your knowledge!
08PowerstrokeFX4 is offline
post #7 of 11 Old 07-29-2013, 08:19 AM Thread Starter
I have an email into ScanGuage to see how they calculate / dislay it.
My truck is kinda a dog and trying to search for possible issues. The EBP tube is clean but wondering if I have a bad sensor.
post #8 of 11 Old 07-29-2013, 09:08 AM
WoodBoy's Avatar
Scangauge is going to have atmospheric added in like Spartan Dashdaq or SCT Livewire. Mini maxx subtracts it already. So say if you don't want to go over 70psi of backpressure that would be 84.7 on the scangauge, dashdaq, or livewire, but only 70psi on the minimaxx
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #9 of 11 Old 07-29-2013, 09:35 AM
rt_hawk's Avatar
What woodboy said...also your MAP values will also be 14.7+"X"...although some xgauges like the one for Boost, account for atmospheric pressure and subtract it automatically...you can even adjust the math to make the xgauge zero out at KOEO.
rt_hawk is offline
post #10 of 11 Old 07-29-2013, 09:49 AM Thread Starter
Ok, Thanks.
I set up my SG2 on Boost. I did adjust the math so that boost reads 0 (+/- 0.1) psi at KOEO. One of the things I noticed is that when I put it to the floor, the SG2 boost goes to 22.8 psi then stops and the dummy guage will read close to 40psi. So if I am understanding correctly: If I wouldn't have adjusted the math on the SG2, the SG2 would have been reading close to 40psi?
