Rattle from rear - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-22-2013, 07:58 PM Thread Starter
Clayton1985's Avatar
Rattle from rear
*warning* Could be a bit long to explain in full****
May be a minor thing to some but its been driving me ****ing bananas for a year.
Last spring I put on my PMF lift, including 8" traction blocks/bars. When I installed, my leaf spring center bolts fell through and into the big blocks!! Lol
I mavgiver'd up a temp solution (rebar) til I was able to get new bolts. (couple days)
I never had C-clamps so when I went to put in the new center bolts my leafs spread apart, no big deal got bolts through lined up and set in the alignment hole in block..this is where I frigged up...I then tightened while weight of truck on leafs/block etc. These bolts are soft and not gonna take well to too much torqing.
I got them as tight as I can but not sure how well and then stripped the threads off bolt so nut just free spun... I had top plate torqed down pretty tight, everything else tight.
Fast forward to this weekend. New bolts. Installed and tightened while removed from blocks. Top plates torqed to 100ft/lbs.
I get a very annoying jingle from the rear end of truck after bumps/potholes etc and seems to be on the rebound.
Ive tried damn near everything. Ive been under truck numerous times with rubber mallet, ive had 3-5000lbs of gravel in the box thinking weight might change it, no spare tire under box. I 1" ratchet strapped exhaust in a few places to see if any change...nope. Doesnt change when brake applied. No hitch in the receiver, exhaust hangers all in place and in good shape..same for shocks (which are new too). Fuel tank straps solid/good shape. Trying to think what else.... Edit: Tailgate seems solid, side steps are noise free...
I cant replicate the sound any way either.... jumping on rear bumper, smacking everything with mallet.
Im at a loss.....dont know what else to do/try. Didnt do it before lift. I still think its the leafs springs but not sure how or why....so my next move is to buy a new set of leafs......
Anyone want a truck before it falls down the bank?
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #2 of 9 Old 07-23-2013, 04:56 AM
Quoted: 2 Post(s)
i know you said "rattle" but try this, there are rubber gromets on your tailgate or on the bed where the tail gate shuts, put a light coat of grease on them. could be your issue. just a thought.
also, have you checked the heat shield between the exhaust and spare tire? mine was rubbing exhaust from time to time.
Kris
2008 Ford F250 6.4L Crew Cab Short Bed King Ranch
3.5" ReadyLift Leveling Kit, 37x13.5x20 Toyo MT's on stock 20's, Dual Steering Stabilizer, Livewire w/ IDP, KEM, Gearhead, S&B, 5" Flo-Pro, Rudy's EGR Delete and Cold Side Pipe, CCV
p8ntballn2 is offline
post #3 of 9 Old 07-23-2013, 03:13 PM Thread Starter
Appreciate the suggestions.
I tried the tailgate, actually I took the tailgate right off. The heat shield for spare isnt the cause either as its removed, I also had it bent up out of my way I kept hitting my head on it!!
1999 Corvette Cpe
post #4 of 9 Old 07-25-2013, 08:33 AM
NotStock's Avatar
Did a portion of your "temp" alignment pin setup possibly fall inside the block? Fuel tank cap/cord? Tail lights loose?
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #5 of 9 Old 07-25-2013, 09:32 AM Thread Starter
Hey Trevor, the original centre bolts fell inside the blocks!!! One side for sure, can't recall if the other side did too....
I strapped my old camera to hitch last night and got a video, can hear it pretty good, ill try and get it posted soon.
1999 Corvette Cpe
post #6 of 9 Old 07-25-2013, 11:16 AM Thread Starter
Video added
http://youtu.be/NADZuNyhneo
Link to it, I dunno how to embed on this forum.
Its not the parking brake cable/metal bracket on top of rear diff either you see bouncing off diff, I tied if off this morning.
1999 Corvette Cpe
post #7 of 9 Old 07-29-2013, 09:01 AM Thread Starter
TtT. I need some more ideas, im stumped.
1999 Corvette Cpe
post #8 of 9 Old 07-29-2013, 10:26 AM
Did ya ever get the bolt(s) out of the blocks, if not I'd start there...
darenative is offline
post #9 of 9 Old 09-06-2013, 11:48 AM Thread Starter
I removed rear shocks, had box full of rock (realllll heavy), checked a few other small cables but hasnt made a difference...
Lift is coming out I think....
1999 Corvette Cpe
