Intermittent ac issues - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-22-2013, 09:15 AM Thread Starter
Y&R0864's Avatar
About 3 days I was pulling up to my house an my ac just quit blowing. Turned it off and then back on and it started working again.
Then today I get in my truck and turn the ac on and it doesn't blow at all. Until I get a mile down the road and retry it and it works fine and blows cold.
Anybody have any idea what's goin in? Any help is appreciated.
2008 F250 6.4 crew cab lariat w/s&b intake, flo pro egr delete, diamond eye 4" turbo back, and mini max
Y&R0864 is offline
post #2 of 8 Old 07-22-2013, 10:49 AM
RHKA's Avatar
Sounds like your blower motor got a short. Might have to get a wiring schematic, and a volt meter and test your connections.
2008 F-350 LARIAT CC LB DRW 4x4
6" FABTECH LIFT
22" AMERICAN FORCE RIMS, TOYO OPEN COUNTRY A/T LT325/50R22
SPARTAN TUNER(300 HP TUNE WHEN EMPTY)
5" DIAMOND EYE EXHAUST TURBO BACK
RHKA is offline
post #3 of 8 Old 07-22-2013, 12:32 PM Thread Starter
Y&R0864's Avatar
Where is the blower motor located? And the easiest way to get to it?
Is it possible it could just be the resistor.?
Y&R0864 is offline
post #4 of 8 Old 07-22-2013, 01:06 PM
RHKA's Avatar
It's located in the back of glove box, you got to pull out the glove box, then there's going to be black insulation you pull that down then you should have a clear shot. I would actually test for continuity etc. with a volt meter before spending money on parts. It could be a simple fix like a bad ground or something. But when you open it up the resistor is going to be on right hand side of the heater box. Whatever you end up doing, you got to start someplace, Goodluck.
6" FABTECH LIFT
RHKA is offline
post #5 of 8 Old 07-22-2013, 01:27 PM Thread Starter
Y&R0864's Avatar
I will start digging into it as soon as I'm off work. Thanks
Y&R0864 is offline
post #6 of 8 Old 07-22-2013, 04:23 PM Thread Starter
Y&R0864's Avatar
So what does the resister look like?
Y&R0864 is offline
post #7 of 8 Old 07-23-2013, 03:30 AM
RHKA's Avatar
Blower Motor Diagram
6" FABTECH LIFT
RHKA is offline
post #8 of 8 Old 08-02-2013, 11:26 PM
halfregulater's Avatar
Does your cruise control work on an off too? And check your horn as well. Could be a module.
halfregulater is offline
