6.4 powerstroke starter? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-21-2013, 06:27 PM Thread Starter
Big Money's Avatar
For a while i have been have a problem with my starter hanging up on my truck. I know the 08 and up trucks have the automatic starting as soon as u let off the key it keeps goin til the truck starts. The truck starts fine but the starter hangs for about 2 to 3 seconds. It is retrackting back like it is suppose to but it just keeps spinning. Has anyone had or seen this same problem or have a clue what it is i think it has somethin to do with this automatic ignition switch.
Big Money is offline
post #2 of 6 Old 07-22-2013, 10:37 AM
not sure on the problem by my 2008 does not have the automatic starting once the key is turned.
lazlow is offline
post #3 of 6 Old 07-22-2013, 04:00 PM
chachi65's Avatar
Yes I have except not as lucky mine stuck on had to replace the starter
chachi65 is offline
post #4 of 6 Old 07-22-2013, 05:09 PM Thread Starter
Big Money's Avatar
Yea luckily its not hangin on the flywheel it is retracting but it just spins for about 3 secs longer after the truck starts. Im pretty sure its electrical but idk where to start.
post #5 of 6 Old 07-22-2013, 05:12 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
mine either
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #6 of 6 Old 07-23-2013, 09:55 AM
chachi65's Avatar
Well check the relays to see if they are causing the issue maybe going out and not deenergizing quick enough or could be the actual signal to the relay I was told to get rid if the one touch start cause issues
chachi65 is offline
