2008 black smoke - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-21-2013, 10:10 AM Thread Starter
2008 black smoke
ok i have just recently noticed black smoke comming from tail pipe at take off. i have dpf and egr removed but not running any heavy tunes. i hadnt seen any smoke for about 4000 miles with the delete so this seems not normal. What could be causing this? I have no codes showing. The only thing I do have going on is a cracked uppie. fixing this next week. any ideas??
Zacfrd is offline
post #2 of 10 Old 07-21-2013, 10:50 AM
WoodBoy's Avatar
Air filter clean? Cracked up pipe sure isn't helping
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 10 Old 07-21-2013, 11:10 AM
02dura09's Avatar
yeah up pipe isnt helping spooling, dirty air filter or maybe check intercooler boots for pin hole or rub through
2013 CC/SB Lariat Kodiak Brown-22x12 Fuel Mavericks, 35x12.5 Toyo MT's, 4.5" Rough Country Lift, H&S Mini Maxx, Flo Pro dual 5", S&B Intake, 55W HID Headlights/Fogs
2008 Crew Cab Short Box-Sold
02dura09 is offline
post #4 of 10 Old 07-21-2013, 11:30 AM Thread Starter
Can just the bad pipe cause this? Boots look good and air filter is ok
Zacfrd is offline
post #5 of 10 Old 07-21-2013, 11:36 AM
zdawg8394's Avatar
Yes, could be causing the turbo to slightly lag, the engine would be counting on that pressure this sending more fuel that it thinks can be burnt but can't. That non burnt fuel is smoke.
Does the smoke clear up fast? Is your turbo pushing normal numbers?
Like stated above also check filter, should be able to look right at the filter minder and see.
08 F350 6.4 4x4 Lariat CCSB
-BDS 4 inch radius lift - Fox 2.0 shocks - XD monster 20x10 chrome rims - Toyo open country m/t 37/13.50/r20 - Procomp dual steering stabilizer w/fox stabilizers - 2wd valance - HID heads and fogs - escort 8500 x50 blendmounted - CTS insight with dash pod - interior led conversion
"When you nail the throttle in traffic trying to get around someone chr*st I think GM could have mailed me that 400hp faster then I got it out of the truck."
zdawg8394 is offline
post #6 of 10 Old 07-21-2013, 11:36 AM
zdawg8394's Avatar
Didn't see you checked filter, my bad.
post #7 of 10 Old 07-21-2013, 11:44 AM
diesel212's Avatar
My 08 does this on take off and when I get on it hard but I just assume its from no dpf and the tune. I'm running a mini maxx on stock power level w volant intake and 5" flo pro exhaust. been doing it since I installed it seems normal to me
2008 6.4
H&S mini maxx
5" Flo Pro
Volant intake
20" Rockstars on 33's
diesel212 is offline
post #8 of 10 Old 07-21-2013, 12:06 PM Thread Starter
it clears up quick. lossf of low end power due to pipe. turbo dont build boost right away and loosing alot due to pipe
Zacfrd is offline
post #9 of 10 Old 07-21-2013, 12:14 PM Thread Starter
one other thing that was odd when my uppi pipe went was that air flow sensor on the air filter isnt moving. it did have about 1/2 until it indicated change filter. i reset it just to make sure and it hasnt moved since. if the exaust side of turbo leaks will this drasticaly change vacume on intake side?
Zacfrd is offline
post #10 of 10 Old 07-21-2013, 04:36 PM Thread Starter
So what do you guys think?
Zacfrd is offline
