How to change glow plugs - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-21-2013, 05:46 AM Thread Starter
spock91's Avatar
Quoted: 6 Post(s)
I am getting a P0673 DTC and will be replacing the number 3 glow plug. Are there any tricks to changing them?
Did a search and didn't see much.
Thanks
Spock91
spock91 is offline
post #2 of 7 Old 07-23-2013, 05:25 AM Thread Starter
spock91's Avatar
Quoted: 6 Post(s)
Dang no one every have to change one of these before......
spock91 is offline
post #3 of 7 Old 07-23-2013, 09:06 AM
Go to motorcraft's service website and pay for a 72 hour subscription. Download and copy all the information you need. You will need Windows and Internet Explorer to view it. Sucks, but they let you see everything you could ever want to know about your truck.
Expirobo is offline
post #4 of 7 Old 07-23-2013, 01:33 PM
BudDog's Avatar
Quoted: 2 Post(s)
I think it would be foolish to replace just 1. If you have the valve cover off replace all 4.I had 2 bad injectors #6 & #7 and replaced all 8 just in case. I didnt want another bad one to pop up in a month.
96 F350 Dually Super Cab 7.3 Stock. Now I have a Solid Mass Flywheel.
BudDog is offline
post #5 of 7 Old 07-24-2013, 05:22 AM
69Stang's Avatar
A guy I work with had some replaced. He was still throwing the codes after the replacement. He took it back and they had to replace the harness also. They said it was common that once you remove the plug you have to replace the harness also.
2010 F250 Cabela's Edition FX4, 6.4L, 3.55LS.
2011 Palomino Throroughbred 828RLS travel trailer.
"Democracy is two wolves and a lamb voting to have lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
69Stang is offline
post #6 of 7 Old 07-25-2013, 04:50 AM Thread Starter
spock91's Avatar
Quoted: 6 Post(s)
Thanks 69Stang I have the glow plug and will try changing it this weekend.
spock91 is offline
post #7 of 7 Old 07-25-2013, 05:29 AM
I dont know what the 6.4L is like but for the 6.0L, it was easier to take off the wheel well liner and access through there. And the wiring harnesses apparently get brittle from engine heat and break on removal so change the harness as well.
2005 F350 Lariat FX4
AFE stage II cold air intake
MBRP 4" turbo back with no cat
EGR delete, studs, new stock turbo
SCT Livewire with Looney, Street and Tow from Vivian
Nitto Trail Grappler 295/70R18 on
ProComp 7032 black rims
Bilstein shocks
Mini D2S HID retrofit
20" Cree LED bar fog light replacement
medic969 is offline
