Sinister Coolant Filter-causes degas to puke? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-19-2013, 04:18 AM Thread Starter
bts
bts's Avatar
Hi all, I'm at a loss for what is causing this? First, no issues with coolant puking prior to installing the coolant filter. Installed coolant filter as per instructions from Sinister. Truck began puking coolant out of the degas tank. I bought a new cap and installed a pressure gauge, running around the 16 PSI. I valve out the coolant filter and everything is fine, no puking. Tried different tunes and not change so I run the 300 Hot. Right now I just leave the coolant filter valved out which seems like a big waste of money.
Anybody have any ideas? Could I have the return line from the coolant filter "T" into somewhere else?
Thanks,
bts is offline
post #2 of 16 Old 07-19-2013, 05:24 AM
69Stang's Avatar
Are you sure you have the lines correct going to the filter? I'm not sure what would happen if the flow was reversed, but it's something to check.
2010 F250 Cabela's Edition FX4, 6.4L, 3.55LS.
2011 Palomino Throroughbred 828RLS travel trailer.
"Democracy is two wolves and a lamb voting to have lunch. Liberty is a well-armed lamb contesting the vote!" Benjamin Franklin
69Stang is offline
post #3 of 16 Old 07-19-2013, 05:27 AM Thread Starter
bts
bts's Avatar
Good point, ya I checked and double checked.
Thanks
Sent from AutoGuide.com App
bts is offline
post #4 of 16 Old 07-19-2013, 07:45 AM
superduty6.4's Avatar
The coolant filter system is just a bypass system so even if the filter were totally plugged or even installed backwards I think the rest of the system would still flow normally. I'm pretty sure the only way that it would be affected by the kit would be if you tied into the wrong line. Does it only do it when you get on the throttle hard? Was the system low on coolant after the install and maybe just pushing out some air?
08 F350 JOB 1
H&S MINI MAXX HD300 W/S1M
SINISTER EGR/COOLER DELETE
6000K BEAMERS HID HEAD & FOGLIGHTS
KMC XD WHEELS W/NITTO TRAIL GRAPPLERS
2.5" LEVELING KIT
DIESELSITE COOLANT FILTER
ROTELLA EC-1 RATED COOLANT
5" DP BACK FLO-PRO EXHAUST
FLO-PRO CAC PIPE & INTAKE ELBOW
CCV MOD
AIR LIFT 5000LB AIR BAGS W/ONBOARD COMPRESSOR
AFE CAI
PMF TRACTION BARS
superduty6.4 is offline
post #5 of 16 Old 07-19-2013, 08:05 AM
JUGGS's Avatar
Can you get us some pics of your installed setup?
2005 F250 Lariat CCSB/170k mi./6sp Handshaker
Don't Worry
Dieselsite coolant filter, CAT ELC, Bulletproofed and monitored by BPD
Be Happy
SCT SF3, 4" Flo Pro, 2.5" Readylift SST, 35" GoodYear Fierce Attitude M/T's
JUGGS is offline
post #6 of 16 Old 07-19-2013, 10:35 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
^^ This. I cant see how a bypass coolant filter setup would cause your truck to puke even if it was plugged or installed wrong.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 16 Old 07-19-2013, 10:49 AM
ZMANN's Avatar
Quoted: 1907 Post(s)
you mention 16 psi with filter but what is the PSI without the filter ?
I can't see how the filter would have any impact on PSI ever
We Miss you Ronnie
6.0 flush pdf
ZMANN is offline
post #8 of 16 Old 07-19-2013, 01:43 PM Thread Starter
bts
bts's Avatar
Lots of good input, thanks. It's plumbed according to sinister instructions, lower heater hose and return to coolant return hose on top of the rad. I've had it installed for a 6 months and valves out for the last 2-3 so no air pockets. Doesn't matter if I'm running it hard or not- pukes with the filter valves on, doesn't when isolated. Go figure?? Can't really see anything picture wise.
Keep the ideas coming, I'm sure we can figure this out
Thanks gentlemen!!
bts is offline
post #9 of 16 Old 07-19-2013, 01:45 PM Thread Starter
bts
bts's Avatar
Sorry, 16 psi is what the cap is designed for, I just mentioned that to show it's not over pressurizing - not head studs.
bts is offline
post #10 of 16 Old 11-30-2013, 06:06 PM
This is very interesting. I installed a sinister coolant filter last spring and have experienced several puking events since. None before. Mine pukes under a hard pull so I was thinking HGs but I asked over on FTE if anyone thought the filter could be causing a problem. So yours quit puking with filter blocked? I'm pulling my trailer home Monday so I'm gonna block it and see what happens.
stanleyz is offline
