Gear Ratios: 3.31 vs. 3.55 - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-17-2013, 01:28 PM Thread Starter
jumpingjay's Avatar
I'm looking at 2 trucks tomorrow & one of them has the 3.31 and the other one has the 3.55. They are both 6.4L's. I am not real familiar with the gear ratios and what they mean, so I am looking for a bit of advice.
I use my truck for towing a mid size trailer (~4,000lbs), and most of that is city miles. Ultimately, I am looking for better gas mileage, not power, though I am sure that they are related.
So, what's your 2 cents?
Thanks!
2009 F-250, 6.4L 4x4
See what I do with it here:
jumpingjay is offline
post #2 of 12 Old 07-17-2013, 02:04 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
I'd get the taller gears since you tow very lightly and are wanting better fuel economy. Delete that dpf, get s tuner and you should really see a bump in mpgs. Post some pics if you get it!
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 12 Old 07-17-2013, 02:17 PM Thread Starter
jumpingjay's Avatar
What do you mean by 'taller' gears?
post #4 of 12 Old 07-17-2013, 02:24 PM
Big_Smokey's Avatar
Quoted: 10 Post(s)
Bigger gears.......3:55
Big_Smokey is offline
post #5 of 12 Old 07-17-2013, 04:23 PM
Quoted: 8 Post(s)
My bad, taller gears=longer legs lol. I'd get the 3.31
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 12 Old 07-17-2013, 08:00 PM
Capt dong's Avatar
Quoted: 5 Post(s)
I would suggest 3:31 gears if you aren't towing heavy. You'll save fuel.
08 F250 KR
08 F250 XL
Capt dong is offline
post #7 of 12 Old 07-17-2013, 09:12 PM
WD40's Avatar
Quoted: 40 Post(s)
3.55 is lower than 3.31's I see that you live in GA, and the best I remember GA.
has lots of hills, so if your in a lot of stop and go in town the 3.55 would be better.
If it were me I would get the 3.55's because before long you may get a bigger trailer.
Doug
2006 Ford F-350 Crew Cab Lariat 4X2 PSD 6.0 TorqShift Automatic Transmission. Upfitter Switchers Chrome Door Handles,
Oxford White with lower part being Arizona Beige Metallic.
Creative Coating Sprayed in bed liner.
20K Reese 5th wheel hitch.
Mods. 4in. Silverline stainless steel exhaust
BD Diesel XMonitor
Bama ZooDad
35 HitchHiker
Is it time to go camping?
EX-USN
Doug
WD40 is offline
post #8 of 12 Old 07-18-2013, 12:50 PM
44magnum's Avatar
Quoted: 2 Post(s)
I would say go with the 3:55's.
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #9 of 12 Old 07-19-2013, 08:11 AM Thread Starter
jumpingjay's Avatar
Well, I went with the 3:55, mostly because I like the truck better. Hopefully I can get the mileage where I want. I drove it home 350 miles last night, towing the car that I had driven up there to get it & I got 13.5 mpg, so it's time for me to start modding!
I will create another thread to formally introduce myself to the forum since I am not the proud owner of a Powerstroke!
post #10 of 12 Old 07-19-2013, 12:18 PM
44magnum's Avatar
Quoted: 2 Post(s)
You got 13.5 stock? That's pretty good. I get about 14.5 to 15 and I'm deleted. Although that's a good 40/60 mix of city/highway driving.
44magnum is offline
