How do tuners work? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-17-2013, 11:28 AM Thread Starter
HM-8404's Avatar
How do tuners work?
Can someone explain how Spartan and H&S tuners work?
What do they change about how the engines operate? I ask because my truck will not idle worth a crap, after reaching normal operating temp, if I tune higher than 150hp. 150 and lower and it idles smooth as silk, over that and it acts like a clogged fuel filter on a gasser. I love the performance and fuel economy with the 275EL tune compared to the 150EL. I am really disappointed that I am limited to the lower tunes. From what I have read mine is one of many 6.4's that is doing this.
If I knew what the tuner changes to increase the HP that should make it easier to narrow down where the problem is.
HM-8404 is offline
post #2 of 8 Old 07-17-2013, 11:41 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
A tuner changes the ECM and commands the computer to put more fuel thru the injectors, increases the pulse width of the fuel injection, (makes fuel be injected for a longer duration). And alot more but either of these could be causing the problems. Have you contacted your tuner and told them your problem? Most tune writers will tweak their tunes to suit your needs.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 8 Old 07-17-2013, 01:32 PM
WoodBoy's Avatar
There is a lot changed between tunes. Have you tried the 210? I know that the 275 and up change the FRP at idle from the normal 5000-5100ish to 5700ish.
Have you checked for codes even though there probably isn't a CEL? Also, monitor your FRP to see what it is doing
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 8 Old 07-17-2013, 01:46 PM Thread Starter
HM-8404's Avatar
I tried the 210 tune first when I tuned my truck. My FRP stays in the 5000 range at about 650 rpm idle no matter what the tune is I am using. When it starts "missing" it will fluctuate between 4500-5300.
I am throwing no codes at all.
HM-8404 is offline
post #5 of 8 Old 07-17-2013, 02:33 PM
Something's wrong, what tuner do you have? is it new to you? Did your truck run perfect before the tuner? Are the tunes custom?
rdwngs444 is offline
post #6 of 8 Old 07-17-2013, 02:35 PM
Quoted: 8 Post(s)
Good point, did you buy it used and it was tuned for a different truck?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 8 Old 07-17-2013, 02:42 PM Thread Starter
HM-8404's Avatar
Spartan that was bought new. I downloaded the EGR delete tunes. I just loaded the 300EL tune and now my FRP is showing 5800ish. I will have to drive it some tomorrow to see if it misses with that tune. I had not tried the 300 tune in the past because my engine is bone stock.
I actually had the tuner on my truck (210hp) about a month before it started acting crazy at idle.
HM-8404 is offline
post #8 of 8 Old 07-17-2013, 02:59 PM
Quoted: 8 Post(s)
If the tune worked fine in the past... It's not the tune but probably a sensor or possibly one of the fuel pumps. Which one.... I'm not sure.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
