who lives with dripping oil ? - Ford Powerstroke Diesel Forum
post #1 of 21 Old 07-16-2013, 07:17 AM Thread Starter
muntu's Avatar
trying not to be anal....have had a slow drip fixed once already....like a couple of drops only before motor cools....stayed dry for 7000 miles now its back...truck at 30,000 miles total....its livable right? ! such a pain to hand over to dealer if you know what I mean.....who else would live with a slow leak?
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #2 of 21 Old 07-16-2013, 07:27 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Where is it leaking from? The drain plug?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 21 Old 07-16-2013, 06:39 PM
I have a super slow leak on the front cover I think and I'm living with it because my wife will make me sell the truck / divorce me if I take it in the shop in the next year.
08 JOB 1 F-250 Lariat Crew Cab, S&B INTAKE, H&S Blk MAXX, 5" Flo PRO, EGR Delete, Air Dog 165, Upgraded Bellows, MBRP Intercooler pipe, 4" Down pipe, Tial Wastegate, OUO T bars, ARP studs, Bestop pwrbrds
***Legal Disclaimer: Anything I say about my vehicle on this website(Powerstroke.org), pertaining to modifications, is only to gain acceptance from my peers, and does not actually represent anything actually existing on my truck, and thus, cannot be held against me in any issues.
08smoker08 is offline
post #4 of 21 Old 07-17-2013, 06:51 AM
kevinah's Avatar
I just changed the oil this weekend and noticed I now have a slow drip. Mine is the drain plug but I do not plan to live with it. I will tolerate it until the next change though.
kevinah is offline
post #5 of 21 Old 07-17-2013, 10:04 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 58 Post(s)
if it's a bedplate, and it isn't leaking much and I'm out of warranty, sorry EPA, I'm living with it...
drewactual is offline
post #6 of 21 Old 07-17-2013, 01:45 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
all of our diesel drip around the bell housing for some reason. this last time my 6.4 was in for warranty i showed them, the replaced rear main and its dry 8k miles later. first time ever i have had a truck that isnt dripping. our 6.0 always has a piece of cardboard under it in the garage. our 6.7 is dry but its only got 15k miles so we will see
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #7 of 21 Old 07-17-2013, 03:21 PM
pops250's Avatar
Mine has had a leak at since I bought it. Had rear main replaced 2x , rear cover seal and hpfp cover seal , dipstick tube replaced and it still stays wet at bellhousing, just barely enough not to drip but I keep it wiped off every time I drain the seperator. The dealer has told me they can see it has a leak but they just cant find it ( really?). I'm about to the point to just live with it too. But just knowing it has a leak drives me up the wall. My 03 f150 has a small oil leak but I can expect that with 185xxx miles, but this truck only has 66xxx miles and has leaked since I bought it at 33xxx. Sorry for the rant but I know how you feel.
H&S tuned. B&W gooseneck hitch with Companion 5th wheel. Helwig rear sway bar. Edge CTS monitor. Dieselsite coolant filter. Rancho 9000 shocks. Airlift 5000 air bags with onboard compressor. Viair onboard air with 5 gal tank. Flo-pro stainless 4 in. exhaust.
pops250 is offline
post #8 of 21 Old 07-17-2013, 09:01 PM
Capt dong's Avatar
Quoted: 5 Post(s)
If it's at the drainplug, replace the copper washer. My leak stopped after that. After a couple oil changes it's leaking again ever so slightly. Time for a new washer.
08 F250 KR
08 F250 XL
Capt dong is offline
post #9 of 21 Old 07-18-2013, 12:19 AM
Mine has a slow leak that collects on the bell housing. After inspection I believe it's coming from the bedplate. I'm out of warranty so the leak is here to stay. It doesn't drip and hasn't gotten any worse in the last few thousand miles. It drives me crazy knowing it's there but I'm not paying to have the engine pulled to fix a small leak.
mangymarmot is offline
post #10 of 21 Old 07-18-2013, 05:01 AM
Mine is leaking at the drain plug to. I will tolerate it until the oil change then fix it.
2008 F-350 Lariat Super Duty 6.4L Powerstroke Crew Cab
MNMedic is offline
