Viper 5904 driver priority door lock help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-15-2013, 09:28 PM Thread Starter
I'm installing my Viper 5904 alarm right now. I have everything figured out except how to tie into the drivers priority unlock. I have a 2008 f250 crew cab. I have traced out the regular lock and unlock wires no problem. I have factory keyless entry and have access to the wiring diagrams for the vehicle. What I have found is that the driver door unlock and all unlock relay is built into the junction box on the passengers kick panel. What I can't find is if there is a trigger wires for the priority unlock or the driver door only relay.
Anyone have this or the 5901 alarm working this way?
Expirobo is offline
post #2 of 2 Old 07-16-2013, 09:43 AM Thread Starter
I would think someone has a viper here. Maybe not? I really just need someone who is smart enough to find the driver door unlock wire that feeds the driver door unlock relay (if it exists). I can do the rest.
I have a subscription to motorcraft service for a month. What Ford failed to do is explicitly callout a lot of the wire locations. They give you the very minimum amount of wiring needed to trace something down. But there are a lot of wires that I cannot cross reference.
If a smart guy or Ford tech pops in, I'd appreciate any advice.
Expirobo is offline
